Question about Sony Playstation 3 (PS3) Console
My origional 60gb ps3 outputs the menu in 1080p but when i play games capable of 1080p, it downgrades to 720p before playing, how do i play in 1080p?
  • 400 Answers
Does your tv handle 1080p??? If not theres your answer.
Posted on Oct 02, 2010
Vizio won't switch from 720 to 1080p
the game itself may not be output to 1080p. most ps3 games are 720p
Oct 04, 2017 | Televison & Video
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
New ps3,new 40in. samsung 3d led, new monster hdmis yet when i play god of war3 which is capable of 1080i it automatically gives me 720 not even 720p. so i unchecked 720p in setup and it gave me 1080 not...
To change this setting, you must exit the application and change your Video Output Settings from the display settings option in the Settings menu. Make sure the tv is not set on 720p/i and that it is set to 1080i. There has been issues with games that are 1080 downscaling the resolution. this can be confirmed by reading this article. if you provide me with the model of the tv. I can help assist you in ensuring its on 1080p. If you need further assistance please let me know after you try the following above. Thanks, Midwest-tek
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
MY PS3 DOES NOT SEEM TO BE WORK WITH THE HIGH DEFINITON CABLE IT CAME ON FORA FEW SECONDS THEN SCREEN COMES UP WITH NO SIGNAL????
This usually happens when you first buy your ps3 and try to use the HDMI connection immediately. The problem is that the ps3's default output resolution is set to 480i out of the box, and when you try to use an HDMI connection first, HDMI can't do that resolution. HDMI only does 480p, 720p 1080i and 1080p.
See :)
This also happens if you move your ps3 a lot. As it is, HDTV's are either 1080p (full HD) or 720p (including 1080i). If, for example, your tv is 1080p, when you set your display settings in the ps3 menu, it will set your XMB, or ps3 main menu to the max resolution of your tv, 1080p in this case. The resolution will automatically adjust when you start a game, and that game has a native resolution output. That's why, most of the time, games will play in 720p, because that's there native, or original, resolution. This is also the reason why sometimes people have no display on there TV, or a black screen, and when they play a game, that will actually display. That's because your tv can ACCEPT that resolution of that game.
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
How come every time i try and play F.E.A.R on my ps3 it comes up saying (you cannot play this game at the current video output setting)
You need to set your output to automaticly at the screen settings. I think you use HDMI and have 1080p on it. Not every game can run on 1080p. If this won't help try to put it on 720p.
Oct 10, 2009 | Sony Playstation 3 (PS3) Console
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
Some gmes won't play.
Ok. Do you have a NTSC system?
Some PAL games will only run on standard and some will only run in HD and some will run on both if the PS3 is NTSC. The PAL games output at (576i/p) while the NTSC outputs at (480i/p). So honestly, I think that is your problem. You have a NTSC system and PAL games. If you do not have a HDTV then you will need to exchange those games for the NTSC version. Sorry for the bad news. It's not Sony's fault, it's how the game developers coded the games.
I hope this helps. Good luck to you.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
1080p 480p
if you hold down the power button when you turn it on for more than 4 seconds it runs the display setings and puts it in the best possible option
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
