Question about Sanyo DS25390 TV
Sanyo tv ds25390 buzzing sound
The tv is only 5yrs old or less the buzzing noise continues even when you try to turn down the volume
  • 3 more comments
  • Anonymous Oct 26, 2008
    Tv always
  • Anonymous Oct 29, 2008
    i opened up the back of the tv and took a look at the circuit board, its a 12v coil on the board that is making the buzzing. I am nto sure if it is replacable or not but i am going to keep looking.
  • mcdohmeweb Dec 30, 2008
    Sanyo 27" 5-7 years old... buzzing horribly no matter what volume the set is at... funny thing is it started immediately after AT&T Uverse pushed their signal to my box... is this possible? Or just a horrible coincidence?
  • diy-er Jan 13, 2009
    Similar buzzing on a 1990, 27" Mitubishi' Model 2720R. Buzzing louder when bright colors or text on screen. Any suggested solutions?
  • chandragrisw Jan 31, 2009
    buzzing noise
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
Posted on Mar 11, 2009
TV is making a loud buzzing noise while volume control does not effect the buzzing sound.
Posted on Oct 19, 2008
    Problem Solver:
  • 5 Answers
I have found with many televisions that a buzzing noise that changes with the brightness of the screen is usually caused by dust on one or more of the toroidal transformers. Take compressed air and blow it through the air vents at the back of your television or to do a better job you can open it and then blow it out.I hope it helps
Posted on May 03, 2009
The blue part which is buzzing is a relay made by OEG, part number SDT-SH-112DM. It is controlled by the capacitor at C622. I have replaced the capacitor with one of a slightly higher rating as recommended but still have the buzz. Unfortunately the relay is an obsolete part and is very hard to find, at least at reasonable cost. I've read that these coils rarely fail but it looks like modification of a similar relay may be the answer.
Posted on Dec 03, 2013
Copper wire coil under white plastic cover was the source of my set's buzzing. One application of nail polish to the loose windings of this coil three months ago solved problem AND led to clearer picture.
Posted on Mar 21, 2009
Sanyo 25" 10yr 25390 model
a loose connection may have caused this,try inspecting connections on audio circuits
Jul 13, 2011 | Sanyo DS25390 TV
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
What part do i need to replace to fix a buzzing noise on a Sanyo DS25390? Thanks, Jason
This tv problems,have 2 possibilities problems.1 the CRT(Tv tube) itself is dead.This u can hear the CRT Video board connection buzzing noises at the CRT-(Tv tube) head.The CRT is dead,also have a little high volt sparks flashing on the video board components too.2 is the FBT-the Flyback Tranformer is dead.This is a highvoltage transformer,a big black block of plastic with a red wire with a cap hook to the CRT(Tv tube).This will make buzzing sound at the base of the FBT.If it is the FBT-it is repairable,if u still can find the FBT part for ur tv model.This part the FBT is a critical part for the analog tv to work.Require tools and also know basic soldering too a must.
Dec 01, 2010 | Sanyo DS25390 TV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Buzzing in TV is from part sdt sh 112dm. will changing the part quiet the buzz?
C622 is the real problem. It is a 470 uf capacitor filtering the power to the blue relay. Radio Shack sells it for $1.29 part number 272-1030. make sure you observe polarity when you replace it. In other words, the side marked minus goes on the negative side. Check the markings on the old capacitor and replace it the same way with new one. The new capacitor has a higher voltage rating which is even better.
Jun 29, 2009 | Sanyo DS25390 TV
HUMMING/CHATTERING NOISE ON SANYO TV
Confirmation: Lee2fixit's solution also worked on a Sanyo 19" TV Model DS19580with 'buzzing relay'. Chassis carriessimilar relay (Type DG1U 12VDC II TV-5 8A 250V~ also by DEC) at location RL601and a 25VDC 470uF electrolytic cap at C622. After confirming the relay was sound and finding no obviously faultedcomponents tied to it, replaced the cap. Bingo, normal operation and a quiet relay. Will post a follow-up ONLY if the fix failsbefore the rest of the TV .. it's almost10 years old after all. Thank youLee2fixit and FixIt.com.
Jul 05, 2008 | Televison & Video
Buzzing
The SDT-SH-112DM is a SPST Form-1A relay. It was hard to find, so I went to Radio Shack and bought a similarly sized and rated relay that was a DPDT (also from OEG). broke off the NC pins, joined (soldered) the switch source lines & removed the unused NO pin so it would fit in the drill holes... works fine!
May 26, 2008 | Sanyo DS25390 TV
Polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Jan 15, 2008 | Polaroid FLM-3232 Television
SanyoDS25390 Tv good picture buzzing noise
What are you using as a source? If its a cable/satallite box, double check that first. If its a video input or a scart input, swap out the cables. If it still there you could have an input problem or a filter capacitor going bad. Does the hum get louder with sound? If it does it is an input source and or cables. Good luck Ps please dont forget to rate this thread.
Nov 25, 2006 | Sanyo DS25390 TV
TV Troubleshooting
It Could Be A Coil in the set,Or the Yoke on the Back of the Tube,It would not be advisable to tell you to fix it
Nov 18, 2006 | Sanyo DS25390 TV
Televison & Video Logo
2,705 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
