Question about IBM NetVista PC Desktop
Ca't get any display
My machine is IBM Netvista, when i plug in the monitor i cant see anything on display, is my onboard port gone bad, motherboard, pliz advise
  • 86 Answers
Check the cable fro monitor what is going in PC check the litle tiny pins inside on the plug
Posted on May 26, 2008
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
Netvista 6350 lost screen connection after BIOS password reset
If there a separate AGP Video Card in the system? If so, is there also a VGA connector on the motherboard? If you have both, try swapping the screen over to the other one. You may have reset the default video card back to the motherboard.
However, it looks as though you are using onboard video as you appear to be using 256Mb shared RAM for the video memory as your total should be 1536Mb.
In that case, you may need to do a rurther BIOS reset. You can find the complete instructions here
Nov 28, 2009 | IBM NetVista PC Desktop
Do I have a usb port on this pc
Ya the usb port is there definitely , you have to see at the back side of the pannel below the VGA cable i.e the monitor cable you can see a rectangular shaped sockets thats the USB port
Oct 30, 2009 | IBM NetVista PC Desktop
Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
HP Pavilion a1620n monitor won't display
If you have TWO graphics ports (one onboard + one seperate card) then double check you are plugged into the right one !
If you get the same issue with another monitor then it is more than likely that your graphics card is pooched.
If you are using the onboard then you can buy a pci express card to replace / bypass the onboard.
If you are already using a seperate graphics card you may well need mo replace it.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00783668&lc=en&dlc=en&cc=us&lang=en&product=3245025#N770
This is the motherboard for your machine. Remember that if you dont use the onboard graphics you should got into the bios and tell it which you want as primary dislay adapter
Aug 08, 2009 | HP Computers & Internet
Monitor freezes up with multicolor wording or distorted images
Sounds to me like a few possible things...
1) Bad connection to the monitor, check the cable connection, if you see or suspect any damage, buy a new monitor or test with a friend's monitor.
2) Video card could be bad, if it has a video card, you could simply buy a new card to see if it will fix the problem. If the video port is attached to the motherboard (meaning onboard video), the motherboard could be damaged.
3) The motherboard could be bad. Sometimes fried motherboards will garble the screen like this on bootup.
Mar 25, 2009 | IBM Computers & Internet
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
Newly build computer problems
i bet your power supply isnt powerful enuf for your video card.
Jan 31, 2009 | ASUS M3A78 Pro AMD 780G AM2+/AM2 Phenom...
IBM NetVista8305-MU3
Thanks for the note back. It has one vga port on the back and it's on the main(mother)board.
Sep 05, 2008 | IBM NetVista PC Desktop
Netvista AGP slot disabled
I added an FX 5200 256Mb AGP card to a 8307, and the Bios allowed me to enable the AGP port. And reports the device working properly.
May 26, 2008 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
