Hi there, I recently bought new Acer Aspire 5553 laptop and was setting up partition hard drive when it asked me to restart to save changes. When restarted following continuous error was displayed on DOS screen- Check cable connection! PXE-MOF: Exiting Intel PXE ROM. Operating System not found I tried changing the boot up order to have ethernet as first but same error shown. If I try to switch on with ethernet cable connected initially in DOS mode it tries to establish connection but same error OS not found in end result. Can you please help me out? Thanks Sam
    Guru:
  • 1,082 Answers
Go to the BIOS setup screen. Watch the info at boot time and hit the right key (F1, space bar, delete key, etc. depending)
In the BIOS, look in the boot options and take the "other devices" or "other" out of the boot sequence. Also check to see if boot from LAN is enabled. If it is, disable it. PXE is a protocol that will enable you to boot from a network drive or server. When it says that it failed, it is because it could not find an OS on the network.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Posted on Oct 02, 2010
  • sams6669 Oct 02, 2010
    Since bought recently had not created recovery disc, I am not able to see or go into boot options and LAN enable/ disable is it in the same menu..
    I tried to go through boot up menu with / without ethernet cable connected but no difference.
    Do I need to set up specific boot priority order to resolve this?
    Currently it is set up as-
    1: IDE HDD: TOSHIBA MK3265GSX
    2: IDE CD: TSSTcorp CDDVDW
    3: USB FDC:
    4: USB HDD:
    5: USB DCROM:
    6: PCI BEV: Atheros Boot Agent
    7: USB KEY:
    8:
    The exact error shown is-
    For Atheros PCIE Ethernet Controller v2.0.1.9(12/05/09)
    Its Acer Aspire 5553G AMD Phenom II X4 Processor N930 2GHz, 4GB RAM 320GB HDD
  • Jim Winger Oct 03, 2010
    you should be able to disable options other than 1:
    President:
  • 2,992 Answers
That cryptic message is coming from the computer's BIOS, which attempting to boot from a network connection since it's not finding the operating system anywhere else. (The usual boot order is CD drive first, hard drive next, finally the network. Network boot only works in an environment like a school or office where there's a server to connect to that provides the required information.)
Whatever you did to your hard drive made it unbootable. About your only option now is to reinstall your factory image. This may be a problem, though. If there was a recovery partiton on the hard drive, your partitioning operation likely deleted it as well as the boot partition. Unless you have a set of recovery discs, you'll either need to do a fresh installation of whatever version of Windows was preinstalled, or see if a recovery set is available for purchase from the manufacturer.
Acer aspire 5552g recovery disk
Hi , not sure if you need one, there will be a revovery partition on your hard disk.
see link below
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
recovery disks should be available through Ebay
Jan 21, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
How do i reboot my recovery partition from a aspire 3690
Hi
If you have the option to save anything like files and photo's stored on your hard drive you should do this before you attempt a recovery because you will loose all files it will format your hard drive
back to when you bought it
Normally when you hit the power key you also tap the ALT+ F10 key a few times until it gets you
into the acer recovery manager and when asked for a password try 000000 thats is ( 6 zero's ) and follow the on screen instructions
if the F10 option dont work
then restar laptop and tap the F2 key to get you into bios and go over to about the 3rd of 4th option
and make sure that the D2D is enabled if it is not then click on it and change to enable
then click F10 to save and exit
then go back and try the ALT+F10 keys again
Mar 22, 2011 | Acer Aspire 3690-2196 Notebook
How to do system recovery on aspire one
Hi you should be able to do the following, if not you will need an external CD drive & recovery disk.
1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Warning:
It is possible to delete the hard drive partition that has the recovery tool.
If your Acer Aspire One no longer has the recovery partition, you will need
to acquire an external USB DVD drive and then contact Acer for a recovery DVD.
Connect the USB drive to the netbook's USB port and then insert the recovery DVD in the drive.
Hope this helps.
Feb 14, 2011 | Acer Computers & Internet
I need to restore my netbook to factory settings but I don't have a flash drive or disk drive
With Acer One's there is usually a hidden partition that will allow you to recover the operating system to factory defaults without the use of a flashdrive or a CD/DVD drive.
To recover the operating system please follow the below instructions carefully.
That should be it. All you have to do from there is restore any files you backed up before the recovery.
If there is anything else please post back.
Regards.
Dec 09, 2010 | Acer Aspire One Netbook
Restore back to factory settings
If the laptop didn't come with restore CD's then chances are that there is a hidden recovery partition on the hard drive that you need to access to recover it back to factory state.
Restart the PC and press ALT+F10 to get into the recovery mode and restore the laptop, you can also try empowering technology, eRecovery software to restore the machine.
Good luck
Jul 09, 2009 | Acer Aspire 5100 Notebook
Sata hard drive not poping up
just enable your sata by going into your bios/cmos. configure it there save your changes and reboot our pc.
Jun 22, 2009 | Acer Aspire E500 PC Desktop
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
How do i replace a hard drive in acer 2303lc-
Hi there
Put the cd in the drive, restart the PC and hit F2 while it starts, go to the boot options and choose the cd drive as first boot device, hit F10, save and exit, the pc will restart and then will boot from the cd, it may ask you to press any key to boot from cd, you will then see setup screen and the new operating system will start to install.
Good luck and thanks for using Fixya!!
Feb 15, 2009 | Acer TravelMate 2300 Notebook
How to install windows xp on new Acer Aspire L320 computer
you can set the partitions in f-disk on the start up disk of windows 98, reset partitions to 32, format c: drive, take out disk and put in windows 98 cd. and restart computer. your done. windows 98 cd will install. your up and running. please give me a fixya rateing. Thanks farren
Dec 20, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
559 people viewed this question
David Payne
David Payne
