Question about Car Audio & Video
Ford edge SEL 6 disk cd initializing message, cannot load cds....
3 Suggested Answers
SOURCE: ford edge 6 disk cd changer cd error will not
According to the tow truck that just came to pick up my Edge, the cd player killed the battery. He jumped it, turned the radio on and said to let the car run for at least 20 minutes. He says that if you leave the radio ON when you turn the car OFF, it should correct itself. Good luck.
Posted on Jan 08, 2010
franktilt
  • 403 Answers
SOURCE: '02 Ford Explorer 6 CD
Are you using Burned cd's
Posted on Jan 27, 2011
Eject and load error
Most common cause for this is dirty lens, try a cleaner disk, possibly the one with liquid cleaner.
If this does not work , providing that the engine is spinning you may need to replace the lens inside
Mar 15, 2008 | Car Audio & Video
How can 6 CD changer be fixed that stopped working after battery was removed and replaced?
Try putting your radio code back into the system it should be written in the hand book if you don't remember it.
Nov 01, 2014 | 2004 Ford Freestar SEL
Ford edge 6 disk cd changer cd error will not initialize. screen displays OOOOOO . This happened after battery went dead and was recharged. I have tried removing battery cable to reset system but still...
Dec 03, 2009 | Car Audio & Video
CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Jul 29, 2009 | 2003 Ford Escape
Cd error on my Ford 2004 expedition
I have seen this often..assuming there isn't a CD jambed in it....usually means you have to send it out for repair...its most of the time an internal problem.....you can try first is disconnect the plug at the back and reinstall them and turn it back on...If it still shows ERROR....replace the radio... If its a stuck CD...FORD radios DO NOT LIKE homemade CDs, they are to thick, and labels hang it up...If this is the problem use a "needle nose pliers" and extract it the best you can AND DON'T USE COPIED CD's....hope this helps you..GL
Jul 11, 2009 | 2004 Ford Expedition
CD P;LAYER HOLDS 6 CDS DOESN'T WORK
radio is bad needs to be removed and repaired
Apr 21, 2009 | 2002 Ford Explorer
Erecovery management
use an external usb cd or dvd burner
Mar 08, 2009 | Acer Aspire 5720 Notebook
My 6 disk changer wont work
Try to reset? Make sure CDs are compatible, try a diff CD. Check the magazine. What else... Call tech support!
Feb 12, 2009 | 2005 Ford Escape
Open Questions:
Car Audio & Video Logo
520 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
