Question about Coffee Makers & Espresso Machines
Keurig B66 water is coming out of vent and brewing a partial cup
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: water coming out of vent
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Keurig B40.
heatman101
Posted on Apr 30, 2011
heatman101
  • 43501 Answers
SOURCE: Keurig coffee maker model B66 - fails to deposit
heatman101
Posted on Aug 28, 2011
heatman101
  • 43501 Answers
SOURCE: When brewing a cup of coffee, part of the water
heatman101
Posted on Sep 07, 2011
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
My Keurig B66 has a backflo of water into the reservoir every time I make a cup of coffee. I have to hold my finger on the rubber spout to get the correct amount of water to go into the brewing cup.
Hi, not too sure about what your doing to get the correct water, but it sounds like the check valve or one way valve is faulty. Is the water hot or cold that is backflowing. Cold means its coming from the pump. If its hot, its coming from the boiler. Darryn
Sep 23, 2011 | Keurig B66 3-Cup Coffee Maker
My B66 will not allow anything to come out of the dischare side, tank and water valve on supply side are all clear and De-scle mode is showing and started De-scle procedure but it will not discharge...
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 24, 2011 | Keurig B66 3-Cup Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
My Keurig B66 is not pumping or sucking the water to brew. It will brew a cup here and there but not the way it should. There is plenty of water in the reservoir. You can hear it trying to pump the water...
I had the same problem. I called Keurig at 1-866-901-2739 and they are sending a replacement machine to me as they said this problem is not repairable.
Apr 09, 2010 | Keurig B60 Coffee Maker
Mar 25, 2010 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
520 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
