Question about RCA RCR350 Remote Control
Won't change channels. Batteries are fine. - RCA RCR350 Remote Control
    Sergeant:
  • 168 Answers
The remote does not operate your component?
  • You must put the remote in the correct mode by pressing the corresponding component key (TV, VCR•DVD, SAT·CBL) so the remote knows which
    component you want to operate.
  • Remove any obstacles between the remote and the component. Make sure to aim the remote at the IR sensor on the component.
  • Make sure the batteries are fresh and are properly installed. (See Battery Installation on page 3 of the User Manual). Replace the batteries with two new AAA batteries, if necessary. Reprogramming may be required.
  • Reset the remote. Remove the batteries, then press and hold the number 1 key on the remote for several seconds to reset the microprocessor inside the remote. Release the number 1 key, reinstall the batteries, and press the ON·OFF key. If the LED indicator light turns on, reprogram the remote and try again. If it doesn't light up, replace the batteries with new ones.
This and other details can find in the troubleshooting-the-rca-rcr350-universal-remote-control
I hope this help to solve it (remember to rate this answer) Good luck,
Posted on Oct 02, 2010
Samsung AA59 remote control Won't change channels
The batteries may have to be replaced.
Oct 19, 2014 | Televison & Video
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
My wii starts up fine..but once were at the main screen it won't allow u to select any of the channels not even if a games in it...u can glide the remote over the channels and it recognizes them, but...
hi there, it happened the same to me, i only changed the batteries and blew into the button to take away any possible dust in it, because the a button might has stopped working, did you try with a different remote?
Jul 15, 2012 | Nintendo Wii Console
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
My cobra microtalk frs won't change channels or even display a channel at all. All I see here on the display is a big "C" where the channel number is (normally). There is also a small...
Hi. Hope this helps. If the first one doesn't work, go to the next. :-)
1. Plug/pop it into the charger.
2. Take the batteries out and put them back in.
3. Change the Batteries (rechargeables may have died if either used a LOT or not used in a long time).
4. Remove the batteries. Use a bit of very fine sandpaper (200 or 400 grit) to gently sand the battery contacts. Use "canned air" like Dust-off to blow the debris from the battery compartment. Reinstall the batteries
4. Look for a tiny "hole" in the housing that doesn't appear to be for anything, like headphones or external mike's. Unfold a paper clip; gently insert it into the hole until you meet resistance then take it out. This might be the reset button.
Good Luck!
Apr 01, 2017 | Sport & Outdoor - Others
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Channels keep changing
ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Jul 07, 2006 | Toshiba 36A40 36" TV
RCA RCR350 Remote Control Logo
178 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
