Question about Car Audio & Video
2006 ford freestar dvd supplement guide - Car Audio & Video
SOURCE: How to dain radiator 2006 ford greestar 3.9L
ford freestar 2004 trac off message comes on sometimes while travelling and then go off when you stop the engine
Posted on Sep 06, 2009
  • 691 Answers
SOURCE: The DVD wont eject in the rear entertainment
is there a small pin hole near the draw? DVD players often have a manual eject lever you can operate by pushing a straightened paper clilp in the hole?
Posted on Jan 06, 2010
  • 4369 Answers
SOURCE: Who knows where I can get a guide to replace the Heater Core on my 2006 Ford Freestar?
I have the shop manual & wiring book from Ford for your car. If interested, let me know. $25 plus postage.
this is a big job, time consuming. Is it leaking coolant?
Removal and Installation
NOTE: If a heater core leak is suspected, the heater core must be leak tested before it is removed from the vehicle.
  1. Drain the cooling system. For additional information, refer to Section 303-03.
  1. Position the front seats fully rearward.
  1. Depower the supplemental restraint system. For additional information, refer to Section 501-20B.
  1. Remove the wiper motor and pivot assembly. For additional information, refer to Section 501-16.
  1. Remove the LH and RH windshield side garnish mouldings. For additional information, refer to Section 501-05.
  1. Remove the LH and RH A-pillar lower trim panels. For additional information, refer to Section 501-05.
  1. Disconnect the heater hoses from the heater core.
  1. Lower the glove compartment.
  1. Remove the 3 steering column opening panel lower bolts.
    • To install, tighten to 8 Nm (71 lb-in).
  1. Remove the steering column opening panel cover.
  1. Remove the steering column opening panel upper bolts.
  1. Remove the steering column opening panel reinforcement.
  1. Remove the 4 storage console pin-type retainers.
  1. Remove the storage console.
  1. Remove the rear seat floor duct adapter.
  1. Remove the upper instrument panel finish panel.
  1. Remove the LH lower instrument panel bolt.
    • To install, tighten to 12 Nm (9 lb-ft).
  1. Remove the LH upper instrument panel bolt.
  1. Remove the 4 upper instrument panel bolts.
  1. Remove the upper instrument panel cowl bolt.
    • To install, tighten to 5 Nm (44 lb-in).
  1. Remove the 4 instrument panel center support brace bolts.
  1. Remove the LH instrument panel support bracket bolt.
  1. Loosen the RH instrument panel bolts one half of the bolt length, but do not completely remove the bolts.
  1. Working through the glove compartment opening, remove the RH instrument panel support bracket bolt.
  1. Position the LH side of the instrument panel slightly away from the dash panel.
  1. Remove the heater core and evaporator core housing support brace nut.
  1. Remove the heater core and evaporator core housing support brace bolt.
  1. Remove the heater core and evaporator core housing support brace.
  1. Remove the 4 floor duct screws.
  1. Remove the floor duct.
  1. Remove the 7 heater core cover screws.
  1. Detach the wire harness from the heater core cover.
  1. Remove the heater core cover.
  1. Remove the heater core.
  1. To install, reverse the removal procedure.
  1. Fill the engine cooling system. For additional information, refer to Section 303-03.
Posted on Oct 31, 2011
SOURCE: 2006 Ford Freestar turns off every 700 miles, and after a couple of days I'm finally able to start it again. What is the problem?
I had the exact same problem, if you don't fix it ,it will get worse and leave you stranded at the most unoportune times. the problem is your inertia switch which is located on the right side of your cargo area in the compartment that holds your emergency jack. this switch has a button that you can depress to overide it's designed function is to cut off your gas supply upon an impact.It have become too sensitive and has failed. I hope that this helps you.
Posted on Sep 02, 2012
SOURCE: Snow Tires without TPMS on 2006 Ford Freestar
I've used non TPMS winter rims on my 2006 Freestar for years. Everything works fine except that the TPMS monitor indicates a low pressure warning, which you can cancel by pressing the reset button on the dash if you want to view other information on the digital dash display.
Posted on Oct 22, 2012
Need the code PO722 for a 2006 ford freestar 3.9
Hope, code PO722 Output Speed Sensor No Signal.
Possible trigger for code,
  • Defective Output Speed Sensor
  • Defective Shift Solenoids
  • Defective Engine Coolant Temperature Sensor
  • Defective Valve Body
  • Dirty transmission fluid that restricts the hydraulic passages
  • Defective Output Speed Sensor wiring or connector
P0722 Ford Output Speed Sensor No Signal
http://www.autozone.com/repairguides/Ford-Freestar-Monterey-2004-2006/Diagnostic-Trouble-Codes/4-2L-V6-VIN-2-Auto-5/_/P-0996b43f802e829c
Aug 27, 2016 | 2006 Ford Freestar
How do I remove the door panel moving right on my 2004 Ford FREESTAR
Ford Freestar Repair Manual, Service Manual Online 2004 ...
? 0:43
www.youtube.com/watch?v=g6JN4OSAHvo
Dec 23, 2014 - Uploaded by david gelf
Ford Freestar Repair Manual / Service Manual Online - 2004, 2005, 2006, 2007 If you need a Ford Freestar ...
Jul 28, 2015 | 2004 Ford Freestar
Ford freestar
Suddenly the fans stayed on and the weather does not work, it's hot or cold
My freestar 2006 , help me please .
thanks
josue
Sep 24, 2013 | 2004 Ford Freestar
I just got a 2006 ford freestar the dvd player dont work.what tool can i use to take tht one out and put the new dvd player in
There are 4 small holes 2 on either side of the face,they made a
tool but 4 small nails will work,just insert the nails into the holes
and they will release the metal spring clips that retain the unit
Feb 15, 2013 | 2006 Ford Freestar
Odometer went black.how do i go about getting it out to check ID number
What ID number? Are you trying to find a replacement? There are only 2 kinds used in a 2006 Freestar - with a message center (6F2Z-10849-BB) and without the message center (6F2Z-10849-BB)
NOTE: If the instrument cluster is replaced, the new one must be programmed to work with your engine computer or the engine will not run - it will go into theft-protect mode.
Getting it out is very easy:
1. Disable the Supplemental Restraint System
2. Tilt the steering column to the lowest position
3. Remove the steering column cover
4. Remove the instrument cluster finish panel
5. Remove the screw and disconnect the cable for the shift indicator
6. Remove instrument cluster screws
7. Disconnect the instrument cluster wiring connector
8. Remove instrument cluster
9. Reverse procedure to install
Apr 08, 2011 | 2006 Ford Freestar
The DVD wont eject in the rear entertainment system. I am trying to find an online Family entertainment system supplemental guide
Jan 06, 2010 | 2006 Ford Freestar
yes you will just have a low tire pressure warning on the dashboard
Nov 18, 2009 | 2006 Ford Freestar
I need 2006 ford freestar fuse box schematics. Drivers window not working.
Owner Guide 1st Printing (.pdf). go to (owners guides and owners manuals/ford,lincoln and mercury owners). once pdf opens up then go to roadside emergencies,fuses and relays then scroll down to fuse diagrams. hope that helps.
Nov 01, 2009 | 2006 Ford Freestar
Position a Drain Pan and uncouple the Radiator Bottom hose clamp, pull of the Hose gently, as you may have to reuse it, and let the Coolant go, Cold engine only, obviously.
Regards,DT.
Aug 30, 2009 | 2004 Ford Freestar
Car Audio & Video Logo
204 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
