Question about Belkin PureAV Home Theater Battery Backup with AVR Technology (228685057550) UPS System
Plug it in and nothing happens. no lights or noise. The two surge protection outlets draw power, the other six don't.
    Guru:
  • 722 Answers
Unplug the surge protector (and all units plugged into it) and take it apart - you'll see how the outlets are connected to provide a closed circuit when on. Make sure all connections are secure and carefully put the unit back together.
You should be able to use all units plugged into it.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on Oct 02, 2010
My dell 1220 projcetor doesn't shift to UPS power when current goes off. It starts showing lamp indication. My UPS backup is ok even then this is happening.
Look closely at your UPS or consult the manual. A lot of UPSs have 2 types of outlets. One type supplies power in the event of a power failure, the other offers surge protection only. Either you have it plugged into a surge only outlet or the projector is trying to draw more power than your UPS is capable of supplying.
Apr 18, 2017 | Dell Computers & Internet
My lexmark s405 printer do not turn on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Jan 16, 2012 | Lexmark Interpret S405 Wireless All-in-One...
My breaker blew and this receiver was plugged in to that particular AC outlet. Does this receiver have some kind of Power Supply protection?
Is that outlet is the only circuit on that breaker?
The receiver may not have exceeded its own internal parameters to blow the fuse or enter protection but it (and whatever else is drawing power from its convenience outlets) may have exceeded the rating for your wall breaker.
There is a modest limit on how much extra current-drawing equipment can hang onto the back of this unit. It's probably printed near the outlet(s). Probably 100 watts max.
In general, nothing heavy duty like heaters, amps, vacuum cleaners, TV's should not be plugged into the receiver.
Jun 09, 2010 | Denon AVR-2500 Receiver
Power surge/Control Panel
The control board blew. You will need to replace the control board on your unit and everything will work correctly again. When a power surge happens it will blow the weakest link, and if your system is not on a protected outlet then the weakest link is your control board.
Jun 01, 2010 | Haier ESA3087 Thru-Wall/Window Air...
My Wii stopped working. Nothing lights up.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
Sceptre 17" lcd monitor is plugged in but no power please help!!
Let's rule out the obvious first. It may be that a power surge has blown out the power supply on the monitor but let's check the outlet as well. Plug a lamp into the same outlet that the monitor is plugged into. If the lamp works, the monitor may have gotten zapped. If it doesn't work, plug the monitor into a known working outlet. If it turns on, the outlet is the problem. If it doesn't, your power supply may have gotten zapped in a power surge. This is assuming you don't have it all plugged into a power strip. Perchance would you be using a UPS (uninterruptable power supply)? If not, it's a good idea to purchase one for the next such occurence. You really don't need a heavy duty one. Just one that will give you about 5 minutes or so to power down after you have saved your work so nothing is lost. They also protect against such spikes and surges. Let me know what you find out.
Feb 15, 2009 | Sceptre 17" LCD Monitor
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
Computers & Internet Logo
127 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
