Question about Compaq Armada 1500C Notebook
Good night, i formated the hdd of my compaq armada 1500c, next i install win xp sp2, every time that the computer boot, i see a mesage that says system date and time not set. how can i restore the bios partition in the hdd? can i install the win xp sp2 in the rest of the hdd? thanks
  • Compaq Master
  • 4,340 Answers
There is not a bios partition, as the bios is a firmware on the mother board. You need to press the key specified early during boot up, before the system seeks the hd for load.
Posted on Oct 02, 2010
Am trying to install vista on my windows xp-sp2 but it gives "spinstall is not a valid win32 application......how to install then???
Are you doing a Dual-Boot? With a Separate Partition on the Primary HDD? I'm a bit confused? Are you doing a install on the Primary HDD and installing over the Win XP? Did you format the HDD? Or on a second HDD?
Mar 20, 2013 | Microsoft Windows Vista Ultimate Edition
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Compaq armada 1500
Check MS minimums here:
http://support.microsoft.com/kb/314865
It will tell you if there is any chance in hades of installing XP but if you only 'meeting' and not exceeding, you will be disappointed.
If (as I suspect) you are running 98se, you might be better off reinstalling.
I am not enamored of the differences.
Aug 23, 2008 | Compaq Armada 1500C Notebook
HELP
Are you trying to upgrade 95 to 98SE or just new install of 98.
What you may have to do is
  1. insert win 98 boot floppy
  2. boot with cdrom support
  3. at the prompt change to cd drive E:\ (press enter)
  4. at the E:\ prompt type cd Win98 (press enter)
  5. at the E:\Win98 prompt type format C:\ (press enter)
  6. confirm all data will be erased
  7. reboot with floppy in and at the a:\ prompt run FDISK to see if the full size of the hard drive is available. (option 4)
  8. If everything is normal exit fdisk reboot with floppy, choose with cdrom support, type in the cdrom drive letter (usually e) and cd Win98(change directory Win98)
  9. at the win98 prompt type setup (press enter) and follow the prompts.
May 30, 2008 | Compaq Armada 1500C Notebook
Compaq armada 1500c
Is it the Operating System you are trying to install?
or the service pack 2 for WinXP?
If it is the OS click on the ASK ME tab under my User ID and leave your contact address, I will send out the 3CD set for compaq Armada/Presario to load the OS and Applications.
If it is the Service pack, don't install SP2, Install SP3
The release candidate 2 is in English, German, or Japanese.
Down at the bootom of this link's page, select the language you want and download approx 315mb
Mar 26, 2008 | Compaq Armada 1500C Notebook
PC is frozen when I press WIN-key
Do you see the Hard Disk Light ON during the time your computer is frozen? If that is the case there maybe an issue with the Hard Disk Controller.
When you installed a new version of Windows XP, did you format your entire Hard disk? (Just to make sure that your computer doesn't have a viral infection?)
Also, is it that the computer freezes when you press Alt+Enter ...or is it like the computer freezes after you press the Windows Key and then Alt+Enter?
Have you tried the Alt+Tab Combination?
Oct 16, 2007 | Compaq Evo D500 PC Desktop
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada 1500C Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
