Question about Alesis Multimix 16 USB 16-Channel Mixer Spdif System
My alesis multimix usb 16 suddenly made a weird popping sound and some smoke was released from within the unit. Now it won't stay on. It simply flashes and then turns off. What can I do?
4 Suggested Answers
SOURCE: wont install in my vist computer
I have the same prolem
Can everybody help us please
Posted on Aug 27, 2008
SOURCE: Alesis Multimix 8 Audio driver wont load
the mixer does not work damn that stuff.
Posted on Jan 30, 2009
cnavarro
  • 2460 Answers
SOURCE: does any one have a alesis multimix 8 manual
Try the website. It only asks for name and email address. http://www.alesis.com/contentmgr/showdetails.php/id/1168/tt/5
Carl
Posted on Dec 29, 2009
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
I AM LOOKING FOR A N ALESIS 8 CHANEL MULTIMIXER THAN CAN BE USED WITH 220V
Since this unit uses so little power, I would recommend a small stepdown transformer. A 20 or more Watt one is sufficient. DO NOT use a convertor that is intended for appliances like hair driers.
Here is a link... the smallest would work and costs $8... I don't know how they can make them for that. You might consider getting a bigger one if you get other equipment to run as well.
Finding the special power adapter that uses 220 and is compatible to the Alesis would cost much more.
Mar 14, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
Multimix 16 usb 2.0 is no longer recognized by computer. Tried multiple cables and 2 computers. Could the usb port on the mixer be fried? Can I get a replacement usb board for this mixer?
Same thing happened to mine when I first got it. Alesis replaced the USB chip at no charge. Worked for a while, but now I only get 10 inputs instead of 18. Love this mixer on so many levels but the USB on it is completely unreliable. When the USB works, it works great. The problem is getting it to stay working. I suggest contacting Alesis for a repair. I'm still wrestling around with them over my 10 input issue. They say when they tested it there was no trouble found. I'm not convinced this is the truth. Good luck!
Sep 19, 2010 | Alesis Multimix 16 USB 16-Channel Mixer...
Clip light on Multimix 12 Firewire always on
I have just gotten the same problem. In my case it worked fine for almost three years and one today I turned it on and this loud humming noise + the red clip light always on appeared. When I hit solo button on channels 9-16 the humming disappeares but the light would not go away. With solo on humming get louder on the mic channels individually (1-8). I am puzzled... No solution so far
Sep 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Alesis Multimix 8 USB won't be recognized
There are NO drivers to be installed for this device. Plug in the usb to the device, and the PC once the PC is running turn on the mixer. XP should inform you that a USB Audio Device has been found & installed. Any software you use for rec'ing will let you choose what sound device to use, select USB Audio Codec.
May 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Wont install in my vist computer
May 08, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Alesis Multimix 16 USB 16-Channel Mixer Spdif System Logo
59 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
