Question about Amana ARGS7650SS Gas Kitchen Range
Pilot light out?
The burner no longer makes the clicking noise when the switch is in the 'lite' position, and doesn't ignite. Gas is still coming through, as the burner can still be lit just fine with a match. It was working fine earlier today, but it's been a very windy day. But the owner's manual makes no mention of a pilot light. Thanks.
  • rdesign007 Jun 29, 2008
    The burner no longer makes the clicking noise when the switch is in the 'lite' position, and doesn't ignite. Gas is still coming through, as the burner can still be lit just fine with a match. The owner's manual makes no mention of a pilot light or where to find, if it is an Igniter . . . Thanks.
  • zmar Jul 06, 2008
    my pilot light on the top of my stove will just flick but will not turn on
It fixed itself and worked fine the next day.
Thanks.
Posted on Jun 02, 2008
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Tom
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
Nov 30, 2009 | Televison & Video
Cleaning lady accidently sprayed windex near our 6 yr old gas GE profile stove. It now makes a clicking noise. What should I do.
Hello there:
the clicking sound that you are hearing is the igniotor trying to lite the pilot s but the pilot lite is out what you can do is first lite all of the pilot lites manually and then start the burners normally as you would and now they should work ok
Also if you contact you local gas/ electric company they will come to your home and lite this stove for no charge ok?
I hope this is very helpful for you
Best regards Michael
Nov 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Gas stove top not lighting - gas is on/electic to appliance is ok
Is it a (relatively) new stove - i.e. piezoelectric spark igniters?
If so, is there a "lite" or "pilot" (or some such) position on the knob? On most stoves you have to turn the knob to that position, it starts clicking, you may smell a little gas, and then it lights.
Is that happening?
When you turn it to the lite position, can you see a little spark in burner. Often these igniters stop working and need to be replaced.
Let me know.
Mar 13, 2008 | Kitchen Ranges
Amana ARGS7650SS Gas Kitchen Range Logo
158 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
