Question about Health & Beauty
I have the conair vortex foot spa with whirlpool action and have lost the directions on how to use it. How much water? What setting is used for what? How much soap?
2 Suggested Answers
dayminner
  • 159 Answers
SOURCE: need an operator/how to manual
If you know the model number you can type it in on the website just to the right for the user manual:
http://www.conair.com/cnt_ib.php?action=filter&type=category
But this one seems closely related to what you have so it might work just as well as guide:
http://www.conair.com/cnt_ib.php?action=download&id=980
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Posted on Jun 04, 2011
How do I sanitize a foot spa
run a bleach solution thru it. be sure to rinse it well after wards.
Feb 15, 2015 | Conair Relaxing Foot Spa
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Bubbles are not working on the right side of the foot spa
Depends on how the jet is set up. Many use a venturi device that pulls air through it as water runs out the jet. Many times people will stick their fingers in the jets and knock the venturi out of place preventing the air from being drawn out. If unit has an air pump, I would check for blocked lines.
Apr 02, 2013 | Pool & Spa
Please tell me how to get an instruction manual for Weight Watchers scale Conair WW87
Conair has the manual on the product site: http://www.conair.com/weight-watchers-glass-body-analysis-scale-p-940.html . Scroll down for the link on the left. The direct link to the manual is http://www.conair.com/instruction_booklets/ww87_11ad124065_ib_FINAL.pdf .
I hope this helps.
Sep 18, 2011 | Home
I just need to know how to set the salt water system. i have an 18ft pool and have put 3 bags of salt in so far.
You don't say how deep it is. Since you say 18 foot pool, I presume it is round. AT 2 foot depth = 3817; 3 foot depth = 5726 gallons; 4 foot depth 7634; 5 foot depth is 9543. Your salt bag should tell you how much to put in referencing the gallons.
I hope this helps. Thanks for using FixYa.com
Jul 09, 2011 | Intex Automatic Salt Water System for ...
Need an operator/how to manual for the Conair Body Benefits Bubbling Foot Spa
Hope this helps!
~~Dayminner
Jun 04, 2011 | Health & Beauty
Lost manual
At initial startup add 290 pounds of salt. Add 75 pounds if low salt warning appears. Set the timer to run the pump for 10 hours per day.Get a downladable owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Lost instructions for bmi and special feature settings
Conair Support – Online Tech Help to Troubleshoot Problems
by: Guest1223497 in Conair Weight Watchers WW-87 Body Fat Glass Scale | 9 months , 28 day(s) ago | 10 ... Manual or Instructions for Conair CID502 Phone ...
livesupport.maybenow.com/Conair
Oct 04, 2009 | Conair Weight Watchers WW-87 Body Fat...
Operation my Pentair 2" Pvc, 3 Way Lube Free Diverter
Every valve is unique to the system in which it is plumbed. You cannot specifically say that there is one way to turn a valve and then apply it to your situation. So, there is a way to determine what you need. Three way valves should be plumbed with the water flowing into the valve at what one would recognize as the "leg" of a letter "T".
Assuming the valve is plumbed this way, the source of flow to the other ports is either from the pool/spa or to the pool/spa. for a valve plumbed in front of a pump, the direction is from the pool/spa. For the other 3 way valve, it is to the pool/spa.
The easiest way to detemrine flow is point the valve handle to one direction. Keep in mind that water flow travels under the valve handle. So, if you see water flowing from your skimmer at the pool, the direction the valve handle is pointing is FROM the pool. The opposite port of the valve (180 degrees) is FROM the spa. Do the same for the other valve. If water flows to the spa with a jet action as opposed to a small trickle, you have directed flow TO the spa.
In general, both handles will be pointed in the same direction. At times, they may not so that is why you need to determine flow and then label thew ports.
It is not wise to run a system with the flow not set for POOL suction/POOL return or SPA suction/SPA return. Having the valves in opposite direction can result in an elevated spa draining to a level equal to the pool.
Nov 02, 2008 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
Health & Beauty Logo
141 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
