Question about ASUS P4V800-X (90-M8LBR0-G0EAYZ) Motherboard
My motherboard used to boot but got problems many times. Since I found that one of the RAM memories had a problems, I removed that one. But suddenly, when formating the Hard-drive and trying to install Windows XP the PC have freezed. When I've tried to restart, it did not boot anymore. So I decided to buy a PC Analyzer card (for PCI) and analizing the result I didn't get an answer because the error was 00, which means nothing for an AMIBIOS. I don't know what to do.
  • ASUS Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 03, 2010
Does no show display and bios beeps once then three time then three more time then again once more.
Regarding the Beep codes try removing the Memory Rams one at a time and see if the computer will turn On properly with 1 RAM at a time, if you have an expansion video card, try removing the video card and use the internal video on the motherboard see if it will boot without any errors.
What you are experiencing is a no POST issue, you do not see the BIOS as you mentioned,remove anything expansion on the motherboard and do the RAM Dance, try One RAM at a time as mentioned and try each RAM on all the Memory RAM slots Available to find out if it will be a RAM causing the issue or possible a bad Memory Slot on the Motherboard.
Oct 18, 2011 | Computers & Internet
Got a problem with my pc. It suddenly intermittently doesn't POST. It boots 1 out of 15 times. When not booting, it turns on, no beep, after 2 seconds, turns off. Then I have to wait around a minute before...
It may be that your motherboard is dead. I have had this problem before. Here are some things you can do to troubleshoot:
Remove video card then plug back in or try alternative video card if you have one.
Isolate each memory stick in your RAM. This may identify RAM problems.
Try a different power supply in your PC or at least reconnect every connection for your current power supply.
Try clearing the CMOS by switching the CMOS clear jumper
Mar 13, 2011 | MSI AM3 890GXMG65 Motherboard (7642010R)
Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
post a coment if this does not work.
thanks,
wonder
Sep 18, 2009 | ASUS P5VDC-MX Motherboard
Did not boot and with 3 beep sound
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
Two rams stopped working in intel d101ggc from today
You've got either mismatched RAM memory or 1 of your sticks are bad. You can isolate this by booting 1 stick at a time. If the machine boots fine with both sticks (one at a time) then they are mismatched or your motherboard isn't configure to handle the 2 sticks together (not very likely but a possibility) Hope this clarifies your problem All the best!
Greg
May 12, 2009 | Intel D101GGC Motherboard
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
RAM Upgradation Problem
Your K8V-MX has 4 memory slots. The slot closest to the CPU is DIMM A1, to its right is B1, & than A2 & B2. Your memory should be matched if possible but in your case with 1xGB & 1x512Mb the memory should be placed as such. The 1Gb in slot B1 & the 512MB in B2. Check your manual for more configurations.
Dec 05, 2007 | ASUS K8V-MX Motherboard
ASUS P4V800-X (90-M8LBR0-G0EAYZ) Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
