Question about Lexmark Office Equipment & Supplies
My Lexmark 5600-6600 keeps on having paper jammed no matter how many i insert in the feeder
  • 49 Answers
SOURCE: MP390 paper jam at feeder
First thing that comes to mind is that SOMETHING you (or someone) fed in, had a paper clip, staple, crinkle or some other unnatural thickness on one side of the paper - and it's stuck inside the feed mechanism.
I had the same exact thing with the feeder on my shredder. You have to get right inside you printer to find the problem.
Watever it may have been probably got stuck in the paper path so EVERYTHING from that point on gets skewed as it gets sucked into the printer and jams.
Can you get "IN" to clear the path?
Posted on Mar 30, 2008
SOURCE: Lexmark 5400 series paper jam
I'm having the same problem on the Lexmark 5400. Will print in black and white and copy in color. Any suggestions?
Posted on Dec 20, 2007
SOURCE: Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Defaulted the printer.
Check the cable form mp feeder connecto main board.
Check paper flag in placed the sensor.
Timming of mp feeder.
it hard happen to the maun board...
Posted on Jul 16, 2009
  • 226 Answers
SOURCE: Lexmark 3500-4500; how do you open casing to look
try cleaning the rollers with alchohol it should open from the top
Posted on Jul 20, 2009
SOURCE: I have a Lexmark 5600-6600 series usb printer and
hi
you can get the Drivers of the Lexmark Printers from the Following Link
http://support.lexmark.com/index?page=home&locale=en&userlocale=EN_US
the manual as well.
take care
Tx
Posted on Jan 29, 2010
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
I don't see a paper jam, but that is the error i keep getting. it will let me print or copy anything. the printer i have is a lexmark x5470
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 13, 2009 | Lexmark X4650 InkJet Printer
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Jamimg paper
your printers paper feeder is jammed.needs quick printer servicing to solve this problem.
Dec 28, 2008 | Lexmark X6170 All-In-One InkJet Printer
My fax machine/printer is saying i have a paper jam. there is no paper jam. i am looking in and throughout this machine. i need to print important papers on a daily basis. i need my machine fixed or a...
Normally the machines are right about paper jams, no matter how small a piece of paper it is.
Check in feeder tray, open all doors, look under rollers....etc.
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Print wont print
You have the paper inserted wrong in the printer. The paper should be inserted behind the feeder wheel that is on the right side of the feeder shoot
May 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
