Question about Dirt Devil Ultra MVP Vacuum
I need to put a new belt on the Ultra hand vac 8230. How do I get the cover near the belt off?
  • 377 Answers
If you go to this URL:
http://www.dirtdevil.com/manuals/?id=497300a5-3758-479d-a8e5-0555f40193f0
you can see the pictorial of what you need to do to change the belt.
Posted on Oct 03, 2010
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
The brush does not turn on
Needed new drive belt Flip over vac take screws out of peace covering belt Can get new belt at vac shop or Canadian tire should say belt size on the belt cover does on most vac s. if not bring your old one with you
Feb 16, 2013 | Vacuums
On our eureka world vac 9834 we cannot figure out how to remove the roller so we can put a new belt on
On this particular model the TOP cover is removed. There are 2 phillip screws near the roller and 2 tabs near the back wheels (push in with a flat screwdriver while pulling apart). Pull the hose through cover for easy cleaning. Everything I watched or read were for other models, where the bottom cover was removed :-(
Feb 10, 2011 | Eureka Boss 7601 Bagged Upright Vacuum
I have got the brush roller off but can't see how
You have to take off the bottom plate that covers the brushroll and put the belt on the brushroll. Then stick the belt into the slot going to the motor part of the vac. Then you can put the plate back on. Next, you have to take the top of the vac off. With the vac upside down,using a straight edge screwdriver and release the pressure locks. There are two on each side of the vac,one near the rear and one up near the brushroll. Just put the screwdriver between the top cover and the base and pry. It should be fairly easy. Then you can put the belt on the pulley. I use a phillips screwdriver to strech the belt to the pulley. This is the hardest part to do. The belt number is 38528-040.
I hopt this helped, Joe
Nov 16, 2009 | Vacuums
Broken belt on a Model #U4655-930 How do you get to the engine pully We removed to brush mechanism
This model you will need to remove the bottom plate first and the top cover next. the cover can be gently pryed off with a screwdriver left and right sides from the back to the front. first put the new belt on the roller and then put roller on vac insert new belt thru hole and pull onto the motor shaft. move roller by hand to center on pulley. and then replace hood and screws
Oct 12, 2009 | Vacuums
Belt Broke - Need to replace it
All you need to do is:
1) Get the actual model number of your Hoover. The information you gave is just what appears on the front of the unit, and that's not the model number. You will find the actual model number on a small tag at the rear of the vacuum near bottom, or on the bottom of the unit.
2) Take that model number to a local independent vacuum cleaner store (not a department / big box store, which will have very limited belt offerings), where they will set you up with a new one. Probably wouldn't hurt to call first just to make sure they carry them / have them in stock.
May 07, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
How do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Apr 21, 2009 | Oreck XL Ultra Bagged Upright Vacuum
New noise when vac is run
mine was allowing the roller/beater bar to hit the cover as it turned take the cover back off and ensure the beater is in the right place then that the cover is locked in the right place then you can spin it by hand (power cord unplugged of course) and make sure it is clearing everything. BTW, the belt has to be stretched to get the beater bar in place like on most vac.s
Jan 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oreck 9100C Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=647356
Oreck 9100C Vac
Posted by thecleaner on Jun 04, 2008
How to I replace both belt and brush correctly.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL 9100C Ultra Bagged Upright Vacuum. The best way to install the belt is to put the belt on the brushroll 1st and then install the brushroll, the brushroll has marking on the top and the bottom of the bearings stating NEW or USED / OLD and install them identical on both sides and then use a belt puller to stretch it onto the motor pulley. The best place to get instructions on how to install the belt and brushroll is the owner’s manual and an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Install a new 4476 belt
What kind of vacuum is it you have?
Nov 30, 2007 | Vacuums
Vacuums Logo
391 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
