Question about Samsung Televison & Video
My tv won't turn on. There is power to it, but when we hit the power button, it just seems that the TV is trying to turn itself on, but can't. It keeps clicking, but won't engage or something...
  • twlyscio Oct 02, 2010
    If I haVe the right number it is LN-840410. Does that seem right? The TV is on now, all by itself, but it is taking 10-15 minutes at times to turn on...
  • 10,594 Answers
I need model number of your Samsung tv to diagnose possible cause of problem.
Model number would be written on sticker pasted at rear of tv.
Thanks.
Posted on Oct 02, 2010
  • Shahid Electronics
    Shahid Electronics Oct 02, 2010
    LN-840410 seems amazing model number, please recheck.
    Now tv has been turned On itself after 15-20 minutes that shows problem with weak/leaky capacitors in output section of power supply board of tv.
    If tv does not power up again then it is confirmed that it got leaky/weak capacitors in output section of power supply board, local tv repair shop will replace these bad capacitors to fix the issue.
    Thanks.
I cant seem to power on
Try pressing and holding the button for a second or two. You may also try using a remote control to power on the tv
Jan 06, 2015 | Televison & Video
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
TV won't turn on.
It sounds like you have problem with the switch on the tv itself. try opening the front panel where switch is located and check wiring or maybe change the switch which you can get it online.
May 31, 2007 | Zenith IQB36B42W TV
Scrolling Channels
You probably have a bad channel down switch on the TV. This is common if any kind of liquid spilled inside of the TV near the controls. The other possibility is just a stuck button on the control pad itself. Sometimes the plastic warps a bit causing to rub against the cabinet causing it to stick. Try moving the button and see if it has free movement.
Mar 13, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
