Question about SanDisk Sansa E280 MP3 Player
Bad Track Hi, i have a Sansa E270, but after downloading 1 track from my PC, the song would not play and came up with `Bad Track` on my Sansa. How do i remove this from my player, as the track is not showing on my PC to delete it !
  • 8,596 Answers
You will probably have to reformat the player, but the "bad track" message could also be caused if the songs you are trying to download have an expired DRM license.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Bad track on my sansa e270
may the format is not mp3, it must be i pod compatibel
Aug 05, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 next song play problem
if you are holding it down (all you are doing ff or rewind), but if you tap it will skip...plus you can also go to menu settings playback settings and change the skip / backward from seconds, mins and whole track...
hope this help
Jun 30, 2009 | SanDisk Sansa e270 MP3 Player
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Cannot delete "bad track"
try formatting your mp3 player and then syncronizing songs back on to the mp3 player.
Sep 13, 2008 | SanDisk Sansa E280 MP3 Player
Bad track
That means that somewhere in your music collection is a song with bad formatted ID3 tags. You can download an ID3 tag tool like MusicBrainz Picard to go through your songs and determine which tracks might be bad.
Aug 23, 2008 | SanDisk Sansa E280 MP3 Player
Sandisk sansa m250 MP3
Select Recently Added, Artists, Albums, Songs, Genres, My
Top Rated, Playlists, Podcasts, Audiobooks, or Recordings (Voice). - to view songs by album, artist, etc.
Or remove the track lisitng from the ID3 tag completely.
Jul 05, 2008 | SanDisk Sansa m250 MP3 Player
Bad track
Hu killersfreak.
If this happens, all you need to do, is refresh your whole mp3 player.
Jun 01, 2008 | SanDisk Sansa e270 MP3 Player
I could listen to some songs
Prob need to format the player
1. put player in msc mode (settings menu under USB)
2. go to my computer and rightclick on sansa
3. format box: choose quick format
4. format complete, allow player to stay connected to computer for 10 mins
go to sandisk.com and under downloads, download the updater to keep this from happening again, put the updater on your computer so each time you plug it in, it will look for updates
make sure you do not put questionable files on the player such as itunes or mp4, as they will "bad track"
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
