Question about Dishwashers
Hi my name is Nick and I work at hotel zaza in the Dragonfly restaurant. We own a hatco booster heater and currently it is not working correctly. We checked the fuses and hit the reset button, but still no luck. It is not reaching the 180 degree mark. What can I do? Nick
    Sergeant:
    Champion:
  • 351 Answers
I would check the element that maybe bad
Posted on Oct 03, 2010
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
Make a electric water heater elements come on at same time
1) You want simultaneous operation.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
2) Installation REQUIRES bigger circuit breaker and bigger wire.
Or 2 circuit breakers and 2 wires
Or change both elements to 2000 watt.
http://waterheatertimer.org/Color-codewire.html
3) MUST add ECO-protected thermostat to lower part of tank.
4) Warranty will be void.
5) If tank is rusted, the added heat and expansion could hasten rupture.
http://waterheatertimer.org/Replace-anode-rod.html
6) As general rule, the health department will not allow this tank conversion for restaurant code to meet dish washing consumption unless manufacturer certifies tank.
But manufacturer will not certify ordinary residential water heater for commercial simultaneous application. Commercial simultaneous tanks can cost 2-4 thousand so they can meet restaurant code and deliver sustained high temperatures for washing dishes.
6) Also consider Hatco booster heater for commercial dish washing.
This type heater has 2 sets of non-simultaneous elements to heat large tank of hot water.
Dec 21, 2012 | Rheem Water Heaters
Does this unit need pre heated water?
yes the unit will need to be fed with hot water to work correctly.It has a rise if you want your rinse 180 then you will need to feed the booster with hotter water if fed with cold water it will not keep up under high demand usage.
Jan 16, 2011 | Hatco Compact Electric Booster Water...
Leaking drain, I think?
hatco booster heater leak at pop off valve
Dec 27, 2009 | Hatco C 24 Compact Electric Booster Water...
We need a new thermostat for a Hatco booster heater dishwasher
Try Rick at Restaurant Parts and More in Ohio. Have model and serial number. He's pretty good at getting stuff like that and he reasonable on prices. I'm in Ga. and I have a 3 day turn around on anything I order from him. He's a straight shooter too. If he can't help you he'll try to find some one who can.
Feb 26, 2009 | Hatco Corporation Compact Electric Booster...
Hatco c 12
hi my name is mark. hi limit safety has a red reset button follow link to instructions to adjust rinse temp to dishmachine. i hope you are not using this unit as a home water heater. http://www.hatcocorp.com/productinfo.nsf/AllDocumentationAttachments/14B2C666CC6F114286257107005AC28E/$File/EBOOSTERM-0406.pdf?OpenElement
Feb 09, 2009 | Hatco Corporation Compact Electric Booster...
With the hatco booster water for automatic dish machine
Under normal and regular operation Hatco recommends that the unit be turned on at all times.
If the booster heater will not be used for an extended period of time or will be exposed to freezing conditions it should be drained to prevent damage to the unit.
Jan 28, 2009 | Water Heaters
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart LX 18 needs compatable booster heater
A hatco C9 or C12 would be plenty big enough.I would use the larger kw unit if incoming water is very low,but it needs to be 140 degrees coming in so it doesnt sometimes trip the hi limit.
Oct 11, 2008 | Hatco C 24 Compact Electric Booster Water...
Booster heater quits heating water after a few minutes of use and you must hit reset button to get it to work again. What would be causing this? For Hatco C36208 Booster Heater 3 phase
#1 I would check that you actually have 3 phases connected. #2 I would also check the ground. There could be a loose ground, or depending on the installation, the ground could be defeated by rubber washers in flex lines. Fix this by running a wire from the casing of the water heater to the pipe, bypassing the flex lines.
#3 Replace the thermastat. The thermastat has the reset button on it.
#'s 1 & 2 are very minimal in cost. #3 is still affordable.
Please rate this solution
Jul 23, 2008 | Hatco C 24 Compact Electric Booster Water...
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
