Question about Pass & Seymour #T603WV 600W White 3WY Toggle Dimmer
We can't figure out which is positive and which is common.
If I understand correctly, you are trying to identify wires inside a 3-way switch box?
Common wire is the wire that connects to dark-colored screw. Before taking wires off 3-way switch, it is customary to mark the common wire.
If you already have switch out and can't remember which wire went to dark colored screw I suggest you put old switch back in place and try the wires on different screws until both 3-way switches work correctly. Don't worry, circuit simply doesn't work if wires are placed on wrong screw.
You may also be trying to identify Hot and Neutral wires.
Hot is usually black, Neutral is usually white.
Here's how to test. Separate wires. Turn on power. Use ordinary tester. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare ground wire. Tester lights up on Hot wire. Next, test Hot wire to each wire (except ground). Tester lights up on Neutral.
Posted on Oct 03, 2010
CODE 112 ON A 99 ROAD KING (CARBURATED)
Clatter sounds usally indicate a mechanical problem (or low fluid levels), not failing sensors ...
But error code 112 is failing cruise control: either the idle cable or the throttle roll off switch; it's pretty common.
Jul 17, 2014 | Harley Davidson Motorcycles
New batteries but will not work can't work how to turn on or how to work
There's a few possible reasons that it may not be turning on:1. (simple but common mistake) Make sure the batteries are in the correct orientation. (Positive with positive, Negative with Negative)
2. Is there a switch anywhere that turns the device power source on? Like from ON to DEMO to OFF maybe(Sometimes it's on a little box behind a Velcro flap inside the toy/Or on the foot)?3. Otherwise the wiring in the toy might be faulty all together and you should either refund it or exchange it for another.
Jan 17, 2013 | Toys
Power switch turns on by itself
Bring the mixer to a place that services these appliances. They will have to replace the switch. This is common on appliances.
Jerry G.
Nov 25, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
What is the money instructions for the monopoly game?
You can download full instructions for Monopoly at the following link:
http://www.hasbro.com/common/instruct/monins.pdf
If this was helpful, please remember to leave me positive feedback.
May 13, 2011 | Monopoly Toys
The dryer will not stay on when i switch to on position
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 10, 2010 | GE DWSR483EBWW Electric Dryer
I need to figure out what wires to cross so that i can read my engine code and fix the problem so that my car starts, when i turn the key foward the engine lite comes on and flashes once and stays on...
You can't jump wires to read codes on this model.older modules you could.check engine light will come on and stay on with key in on position.this is normal.Check to see if security light is flashing after you try to crank engine.If so you have to relearn theft module by leaving ign key in run position for about 12 minutes until security light stops flashing.Very common problem
Feb 28, 2010 | 1996 Pontiac Grand Am
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17793&ProdId=385&lang=eng
You will also need Adobe reader installed to view the manual; http://www.adobe.com/products/reader/
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Cheers'
Mike
Feb 28, 2010 | Zerus Intel Desktop Board D815EEA...
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Mike
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Ignition switch diagram 65 mustang
If its not on the steering column, you can figure it out using an ohmeter on the switch leads. Actually, you could figure out the one on the column that way too! just think about what the switch does in each position and attach wires that do it to the post that does it! IE: starter solenoid wire goes to post that is hot when key is turned all the way to start. Main hotlead is the one that is common to all switch positions. run and accessories is to the post that is hot with key on, accessory only is the one only hot with key turned backwards.
Mar 21, 2009 | 1965 Ford Mustang
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Pass & Seymour #T603WV 600W White 3WY Toggle Dimmer Logo
192 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Mike
Mike Squire
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
