Question about Kenmore Elite HE5t Washer
My washer is saying LD and not working - Kenmore Elite HE5t Washer
    Problem Solver:
  • 19 Answers
LD is an error code for long drain. You may have an item stuck in the pump. Unplug the machine! Remove the bottom panel -three 7m or torx head screws. Sometimes 1/4 socket or nut driver will work. You will see the white pump just right of center with a hose that goes to the tub and another one that heads up to the right. Get a catch pan or bucket if you can fit one under the opening to the pump and slowly open the pump by turning counter-clockwise. If you have a tub full of water it may take a few times of tightening the pump cleanout, filling your catch can, and repeating the process. Once you have the water drained you can unscrew the pump cleanout catch filter and remove the clog. It is common to have this happen after washing rugs or small items. Be sure to not overload the tub and it will get items caught between the spin basket and the outer tub that end up in the pump. You may have to look into the small opening on the right where the pump motor/impeller is to make sure nothing has become lodged in there. While you are at it be sure your drain hose that goes into the wall or standpipe is not installed too deep as it will become submerged and cause issues and errors with the most important being foul water being sucked back on your recently cleaned clothing. It should be inserted about 6-8 inches and fastened with a zip-tie or tape so it will not fall out as it drains. Usually the machine ships with an U shaped device that the hose clips into to hold it in a hook shape. I hope this helps.
Posted on Oct 02, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
May tag washer screen say LD and won't drain
Yup, LD stands for "Long Drain." So, it's no surprise you aren't draining. Check the drain path for any foreign objects. Also, check the drain pump and clean it out.
Oct 13, 2014 | Washing Machines
My washer keeps saying ''Ld'' It will not finish the cycle and drain. I Have tried turning it off and even unplugged it for 30 seconds. I dont know what to do!
"ld" is a service code meaning long drainage time
the most likely problem is some lint build up in pump or in the sump restricting water flow into the drain pump
Jul 18, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
The screen on my washer is saying the code LD i dont have a manual and it wont drain completly. I took my clothes out and they were completly soaked with water. HELP! :D
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem
Jan 12, 2011 | Kenmore 22062 Top Load Washer
Says LD on the panel and will not function. Cannot get any of the buttons to respond
ld is long drain error, check pump for debris. i have also had bad controller board cause this error
Oct 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What to do when there is an error saying Ld?
Hi, This error code(Ld) indicates that drain times are longer than expected.
1.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose
2.The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 39" (99 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer.
If Pause/Cancel does not work:
1. Unplug the washer or disconnect the power for one minute.
2. Plug in the washer or reconnect the power.
3. Re-select the cycle and press Start.
Thank You
Sep 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool gold catalyst it will not drain water, reading says LD?
LD = Long Drain...  "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  could be a bad pressure switch, the pressure hose, the water pump..  those are good places to start.
Jul 31, 2010 | Whirlpool GSW9800PW Washer
My calypso is saying ''LD'' I dont know what to do for it.
Ld means long drain. Theres a problem with your pump. The pump for these washers are around 100 bucks. This is a very common with the calypso washers.
Jun 30, 2009 | Kenmore Washing Machines
Error Code LD flashes
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard!
Feb 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite HE5t Washer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
