Question about Kenmore Vacuums
I have an old kenmore canister 116-model 52612200 how do i change the belt i can't take apart the housing and have lost the service manual. any help would be awesome bg
  • 377 Answers
I was unable to find a pdf manual that could be downloaded. I guess Sears wants money for the manuals.
Call 1-800-366-7278 and tell them the model number and they will sell you a manual.
Posted on Oct 03, 2010
Kenmore canisteer vacuum model 116 52513202 belt replace. I can't get the top cover off the powermate to replace the belt.
If you remove the headlight cover you will find two screws that need to be removed, than flip the power nozzle over and you will find a little catch on each side of the cover, if you pull or pry the cover out a little the cover can be removed from the nozzle housing.
Nov 25, 2016 | Kenmore Vacuums
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
I cannot open and replace belt on Kenmore Model 116 (594299900) BELT ( 20-5285
The manual is here and there are diagrams on page 17 and 18 showing how to access and replace the belt.
http://www.hammerwall.com/Manuals/Kenmore/Description/116.20612003/Kenmore%20Canister%20Vacuum%20Cleaner%20Manual/L0705059/
I hope that helps
Jan 26, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at) govacuum.com.
If this helped you, please click the Helpful button below.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Kenmore Vacuums
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
313 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
