Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
The clock is barely seeable. - Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
  • Jenn-Air Master
  • 2,128 Answers
Have to change out the clock
Posted on Oct 02, 2010
Have a Jenn_Air WW30430 - display is barely visable. Can you tell me if changing the capacitor will work?
HI,
You have an LED display, changing anything other than the clock would not fix your problem. I am assuming you oven get daylight directly on the screen as well. Direct daylight can speed up the process of a fading display also...
Hope this hopes
Jul 28, 2011 | Jenn-Air 27 in. Electric Single Wall Oven...
The electric company did one of those blackout things. When the electricity came back on and we set the time, you can barely see the display. Everything else works fine.
Most likely the lcd will need to be replaced...there are 2 lights on the clock control board and what happens is the display light bulb goes out and it is soldered onto the board. if you have some circuit knowledge the light can be desoldered and a new one installed ,but if not you will have to replaced the clock assembly on the unit.... not sure what brand you have as you did not post...
www.sears.com hit the parts direct link on the top of page and enter the model number and a parts diagram will come up and availability and price...
Feb 04, 2011 | Ovens
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
Jan 07, 2011 | Frigidaire FEB27S5A Electric Single Oven
THE DISPLAY PANEL ON MY OVEN DOES NOT DISPLAY THE
replace defected control board.some of the cap on control board leak.
Jan 27, 2010 | Thermador SMW272 Electric Double Oven
Fried a new oven
black is 110.v red is 110 v =220 volts white to center terminal . bare to frame of oven .. the damage could be to the pc board and the eoc ( clock) any fans ect . it may be more than you want to spend .. panel is 155.00 the clock is 155.00 fan 70.00 . you may not need all of this ., oven cost 764.00 / repair it .. mm /
Dec 03, 2009 | Maytag MEW5527D Electric Single Oven
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Clock
well I theres aproblem with the microcomputer, and would need to be replaced to fix the "dimming" numbers, didnt get full model, but check the partial number supplied and the board alone can cost from 180-325. how old is the unit. smettimes depending on model the manufactuer will warrantee part for 5 years.
Apr 02, 2008 | KitchenAid KEBC247 Electric Double Oven
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
185 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
