Question about Vivitar ViviCam 5024 Digital Camera
How do functions work accessing LCD. camera given as give w/ no instructions. having problems with mode button and arrows to access icons on LCD
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
You may download a copy of the manual here.
Posted on Feb 27, 2012
How to set the date and time
Setting the Date, Time and Date Stamp:
Use the following procedure to change the date and time setting.
1. Slide the Function switch to the capture mode.
2. Press the Mode button twice to turn on function menu. Press the Shutter button to confirm.
3. Press (up arrow icon) or (up arrows icon) to adjust the date and time. Press ◄ or ► to advance to the next setting.
4. When finished, press the Shutter button to confirm the setting; press the Menu button to return to the main menu, press the Mode button to exit the menu.
Jul 07, 2011 | VistaQuest VQ-500 Digital Camera
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Accessing functions: sepia and B&W effect
You may be selecting the wrong option on the menu. Here is the page from the manual on how to set this mode. You should be able to set B/W and Sepia in manual mode.
Feb 23, 2007 | Canon PowerShot S500 IXUS 500 Digital...
“Virtual mode” button
From the arrow pad, select the up arrow (Scene) to access the scene modes.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Macro Mode
The MACRO MODE is easily accessed via the arrow pad on the back of the camera. Press the left arrow key, which has a flower icon, to start the MACRO MODE. Press the down arrow key to select the flower icon in the menu. Then press the OK/MENU button; camera is now set for close-up photography. Remember to turn off the MACRO MODE when you begin shooting subjects beyond the focus range of the MACRO MODE.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Macro mode
The Macro Mode is easily accessed by pressing the second oval shaped button to the left of the arrow pad on the back of the camera. This button is designated by a green colored box with a curved doubled headed arrow – which will rotate the image file when in view mode. The same button also has a flower icon, which represents MACRO MODE when in Shooting mode. Pressing thios button in Shooting Mode displays a menu where you select three options: OFF, Close-Up or Super Close-Up photography.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Activate the macro mode
The Macro Mode is easily accessed via the arrow pad on the back of the camera. The right (>) arrow key, which has a flower icon, is depressed to start macro mode. Press OK and you have set the camera for close-up photography.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Macro mode
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Vivitar ViviCam 5024 Digital Camera Logo
18 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
