Isatap adapter driver - Computers & Internet
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
Try intel drivers
Posted on Oct 02, 2010
I can install the isatap adapter in safe mode but when I restart the adapter has a yellow triangle ?
It means it is not succeed, probably it is not compatible, or it needs special settings.
Mar 01, 2014 | Computers & Internet
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
I need microsoft ISATAP adapter #3 driver
you can try this:
Step1:
However, try the below steps to fix the issue you are experiencing:
1. Click on Start, type Device Manager in the search box.
2. In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
3. Still in Device Manager, click Action and select Add legacy hardware.
4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next.
5. Select Network Adapters and click next.
6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
7. Click next and finish the remaining wizard.
Step2:
The ISATAP is related to Internet Protocol 6.
Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address.
however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this:
Disable but leave ISATAP in the hardware list and go to your manufacturers Website
and check for Post SP1 Driver updates for your computers Chipset.
Feb 01, 2012 | Toshiba Computers & Internet
Microsoft ISATAP Adapter This device is not working properly because Windows cannot load the drivers required for this device.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
I hope this helps!
May 08, 2011 | Microsoft Computers & Internet
In Device Manager under Network Adapters the following have a yellow triangle in front of each one; 1. Microsoft 6 to 4 Adapter, 2. Microsoft ISATAP Adapter, 3. Microsoft ISATAP #2, 3. Microsoft Teredo...
the yellow mark on device manager means the driver has not been installed and the driver is connected to the motherboard use your motherboard drivers CD and install them or you can download them from the net
Dec 15, 2010 | HP Pavilion m7640n PC Desktop
In Device Manager, under Network Adapters I find a new entry called "Microsoft ISATAP Adapter".The yellow explanation mark indicating a problem is present. Status shows "Windows is unable...
Hi.
Let me explain you about the Microsoft ISATAP Adapters.
ISATAP (Intra-Site Automatic Tunnel Addressing Protocol) is an IPv6 transition mechanism meant to transmit IPv6packets between dual-stack nodes on top of an IPv4 network.
It is a Windows Operating System Generic Driver.
This Driver will be installed automatically.
As this is a Windows default Driver, it has no specific functions.
As you are able to view the "yellow exclamation mark", you may just un-install the Driver..
This should not change the functionality of the Computer.
1) Right-click on the "ISATAP Adapter" in the Device Manager. 2) Then, click on "Un-install". 3) This should un-install the Driver. 4) Once you have done the above steps, restart the Computer for the settings to be enabled.
Performing the above steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 23, 2010 | HP Pavilion dv6000z Notebook
Presario c700 ISATAP adaptor no internet?
you need to connect directly with an ethernet cable. then go to the compaq/hp website and go to product support and drivers subcategory and look up isatap adapter driver
Mar 02, 2010 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
