Question about Vacuums
Roomba won't pick up debris
My roomba is only 1 month old and it won't pick up the debris right...not only will it not pick up the debris right, it won't put anything in the actual bin...it only picks up dust in the filter...i have changed everything possible (brushes, filters, cleaned it by the book!) trying to fix this problem and i still can't get it to work properly.
  • 2 more comments
  • taledo2000 Jun 26, 2008
    I am having the exact same problem. My Roomba is a little older (by months) but still too young to be giving out. If anyone has a solution, I would greatly appreciate it.
  • erich_fritz Aug 22, 2008
    I have the same problem. It seems like the brush roller has lost it's "stickiness" and that hair, lint, etc. isn't being swept into the bin. I've tried replacing the brush roller, but to no effect. So now I think it might be the bin, specifically the "teeth" on the bin that rake lint off the brush roller into the bin, but I can't see what might be the problem there.
  • markes14 Aug 26, 2008
    I have the same problem mine is older by a couple of years. It has been picking up the dust but not any debris off the floor. Should I even try changing the brushes?
  • vejron Nov 06, 2008
    We are on the same boat!;/ My roomba got crazy 2 days ago, but the symptoms are the same...besides I bought it in USA and now it works in Europe.
    HELP ANYONE WHO CAN PLEASE!
I had this problem until I wiped the dirt sensor, which you will find under the rollers.
Posted on Jan 02, 2010
The vacuum is broken, mine started working after replacing the dust bin vacuum unit. Unfortunately it is broken again now, after 6 months :(
Posted on Nov 29, 2009
I roomba wont dock
That's usually caused by a charging issue. Could be that the contacts the roomba uses to charge on the base are bad or the contacts on the roomba its self. Here is a good troubleshooting guide. Roomba customer service is very good too, if the roomba is less than a year old they will repair it for you. good luck!
Jul 19, 2013 | Vacuums
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Error 5 what dose it mean
(Condensed from the iRobot site...) "Uh Oh Error 5" or "Uh Oh" and 5 beeps means Roomba's Side Wheel is stuck. Pick up Roomba and with Roomba right side up, push the side wheel up and down a few times to clear debris. Manually rotate the side wheels to clear debris. Blow air through the side wheel pockets (or vacuum them with an upholstery tool on a traditional vacuum) to clear debris. If this doesn't clear the obstruction, then contact iRobot customer support.
Jul 02, 2012 | iRobot Roomba 560 Robotic Vacuum
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
Took Roomba apart to clean and now the pick up brushes start and stop during cleaning. The vaccum is clean but will not constantly spin. Runs great but pick up brushes start and stop. Is there a number...
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
Dec 02, 2010 | iRobot Roomba 530 Robotic Vacuum
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Lights on charger do not light and therfore do not charge roomba.
If the charger doesn't light up, it's broken.
Call customer support at 1-877-855-8593. Be sure to have the Roomba and charger with you when you call-- you'll need them.
May 28, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba discovery
Cleaned the shaft that the spinning brushes are connected to. Used an eyeglass screwdriver to remove the brush.
Jun 18, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
1,742 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
