Question about Conair Compact Garment Steamer Iron
Por donde se echa el agua en la plancha de vapor
Is there a anti-calc tablet or something for de-scaling the HIN 172 ?
Run a tablespoonful of white vinegar through the iron to remove calcium deposits and then use de ionised water from then on to avoid it happening again.
May 19, 2017 | Irons
TENGO I PLANCHA DE ROPA SHARK LIGHTWEIGHT PERO NO SE CUANDO ESTA LA TENPETRATURA al maximo nivel
La plancha tiene dos botones uno para sacar el agua y otro para el vapor y antes de esos dos tiene uno que cuando usted lo precione se mueve la temperatura
Jan 28, 2013 | Euro-Pro Shark Rapido Electronic Iron -...
I pressed a T-Shirt with old transfer material on it and the transfer is now on my top heating plate of my Singer Presser. How do I get it off without damaging my heating plate? I tried to press an old...
aplicar detergente multiuso no Brasil marca Veja Unilever associado a creme com abrasivo, tipo utilizado por mecanicos para retirada de graxa das mãos, pequena quantidade tomando cuidado com os furos do vapor. atenciosamente. @valefelix
Aug 08, 2011 | Singer Electronic Steam Press Iron
I am looking for a manual for a Singer Magic Steamer 7.
TENGO UNA PLANCHA MSP7, LA CUAL PRENDE PERO NO CALIENTA, AQUI EN PARAGUAY NO HAY QUIEN ARREGLE, NECESITO SABER SI DISPONEN DE PLANOS ELECTRICOS Y DESPIES DE LA MISMA, DESDE YA MUCHAS GRACIAS.
MI MAIL ES:
sabatel2010@hotmail.com
Dec 30, 2010 | Singer Electronic Steam Press
How to disassemble a Rowenta DE-871
First remove screw the on the back of the iron. Next pull out on the fill tub on the front of the iron. Pliers might be needed. Another screw will seen at this time. Remove this screw and the sole plate will separate from the top portion of the DE 871.
Oct 02, 2010 | Rowenta Professional DE871 Iron
Need the circuit board for a DE-871A Iron / Iron does not turn on
The electronic shutoff light blinks but won't stay on, so the iron won't get hot. Can this be repaired? Can I disable it?
Dec 14, 2009 | Rowenta Professional DE871 Iron
My DE-480 iron won't heat
check stat,and element,element could be us
Nov 15, 2009 | Rowenta DE-480 Iron
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Aug 04, 2009 | Sunbeam Irons
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Aug 24, 2008 | Rowenta Surfline Iron DE-333 Iron
Conair Compact Garment Steamer Iron Logo
79 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
