Question about Perlick (BC72PG ) Beverage Cooler
We have a perlick beverage center and the compressor goes off every 10 minutes. It is quite loud. Is this normal?
My kegerator out of the blue starts making noises?
Good chance the compressor is going bad. It will likely die shortly.
May 03, 2014 | Danby DKC645BLS Compact Beverage Cooler
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
Compressor Quit
Adjusting the charge or replacing the compressor is not a DIY project, the smell is not likely coming from the regrigerant but from overheated wires.
Jun 14, 2010 | Beverage-Air BEVBM23 Commercial Beverage...
5,200 BTU unit. Compressor and fan both work when first turned on, then compressor quits after 5-10 minutes of operation. Won't turn on again even after 5-minute fan-on cool down. Process repeats after AC...
this could be just a simple fix of cleaning the condenser coils. If semi-clogged, it can cause higher than normal pressures and cause the compressor to cut out on it protector. Check it out.
Jun 11, 2010 | Heating & Cooling
I am getting a flashing message E5 where the temp is normally displayed on my U-Line Beverage Center. I could not find info in the manual on this code?
E5 means that the unit is 10 degrees warmer than the set point for more than 12 hours. You may need service to help you find out if its a sealed system or maybe a thermistor in the wrong location
Sep 28, 2009 | U-Line 2175BEVS-01 Uline Beverage Center...
When we plugged in our kitchenaid beverage center for the first time it is really, really noisy. It has a loud motor noise with a rattle? is this normal, will it go away when it is cooled down?
Did you lay it on it's side? If you did the oil in the compressor may have made it's way down the system. And when you plug in a fridge with no oil in the compressor it will make alot of noise and could damage the compressor. They say if you lay a fridge on it's side you should have it standing up for 24 hours before plugging in so the oil can make it's way back down to the compressor.
Sep 05, 2009 | KitchenAid Architect Series II KBCS24S 24"...
Have a 3 slide door refrig-freezer. Quit working, threw the breaker switch. I pulled the electrical box cover and capacitor was blown. Replaced capacitor, started up again and within 3 minutes quit working...
We need to find out if the compressor has had a burn out first. If you have an ohm meter and a few minutes we will know. Let me know, I hope not, but let me know if you want me to tell you how to test it, Sea Breeze
Jul 18, 2009 | Beverage-Air Refrigerators
Compressor problem, installing the Supco 3-in-1 Relay
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Perlick (BC72PG ) Beverage Cooler Logo
75 people viewed this question
Top Perlick Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Perlick Refrigerator Expert? Answer questions, earn points and help others
