Question about iiyama ProLite E434S 17" LCD Monitor
I Turn on my computer it boots normaly. i catch a glimps of my start up screen and then it goes black. if i turn it on and off it does the same.. help??
Black Screen of DEATH
well try finding someone who repairs coumpters from their home it is alot cheaper. explain your problem they should tell you weather they can fix it
Jun 30, 2012 | IBM NetVista PC Desktop
Black screen right after dell logo
start tapping f8 after you boot the machine, when given the boot menu, try to load safe mode, and see if it loads. if it does, then you need to do a system restore back to before you got the black screen. more than likely windows loaded an updated driver that disagrees with your system. try that and let me know what happens :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 25, 2012 | Dell Studio One 19 PC Desktop
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
My laptop screen goes white after I turn it on. I tried to remove the battery and replace it, but the same thing happens. Every once in a while I see a brief glimpes of the boot screen when I try To...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Compaq Presario CQ60-220US PC Laptop
Computer boots up and then goes to a black screen
Hi ,
Please follow these trobleshooting steps......
Turn the computer off and then disconnect any external devices connected and then when you turn the computer on or as son as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start ?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ,click next until you get the screen that has advance option ,click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost ).If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
ALL THE BEST
May 15, 2010 | Computers & Internet
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
When It goes to loading screen it restarts
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Thanks.
Sep 04, 2009 | Computers & Internet
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
I have a Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook. The problem is that when you turn it on it only boots as far as the windows logo screen and then it goes black.
Press the start button then hold down F8 to go to a black screen with writing. Scroll to boot windows to last known good boot (maybe not exact words, but do last known good start) Click that option and windows should boot to the last good start of your computer.
Dec 14, 2008 | Acer Aspire 3680 Laptop
Black screen with only mouse pointer
well try to start pc in safe mode you can do this by pressing F8 key at windows startup after this remove your display(VGA) driver from device manager and then try to start window normaly if its start normaly then you have problem with your VGA.
And if its does not work then try to reinstall your windows
some times Asus and Msi motherboards have this problem,do nt know wthats is yours
hope you have got answer
regards,
Ali
Oct 30, 2008 | Computers & Internet
iiyama ProLite E434S 17" LCD Monitor Logo
51 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
