Hi There, Ive got a Samsung UE46C5100 LED TV. The picture quality isnt great, especially fast moving images. Non-HD pictures are pretty bad but even HD images aren't that sharp looking either. Are there any settings you can suggest to improv the quality? Thanks
Hi just bought this tv recently too, having the same issue was wondering if you had any luck solving yours?
Thanks
Posted on Jan 13, 2011
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
I have just purchased a 46" samsung led tv @100hz
Try resetting the entire video/audio settings to default. The blur on the picture may indicate that your motherboard is going bad. Recently there was a customer who had the same problem. It was his board. When we tried the AV cables, the blur went away. We tried different HDMI cables and the blur was still there when using HDMI output. It wasn't the TV, and it wasn't the HDMI cables. It was the board going bad.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
May 27, 2009 | Televison & Video
Picture quality for gaming
Match the PS3's output resolution to your TVs (in this case 720p).
Don't sit too close, otherwise you'll start to see individual pixels.
Make sure the HDMI cable is good quality.
As for picture settings, they will very so much according to the viewing conditions that i cannot give you settings that are gauranteed to work for you. But sharpness should always be 0 when dealing with HD content.
If you want to really get the best picture from your TV, try using a THX disc to calibrate it. Luckily these are normally included on Disney PIXAR DVDs, so go find yourself a copy of CARS or something. Follow the instructions of the THX setup, and you should have youself a sweet looking picture in no time.
Hope this Helps.
Apr 28, 2009 | Samsung PS50A457 50 in. Plasma TV
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
295 people viewed this question
Top Televison & Video Experts
Electro Med Services...
