Question about Kenmore Dryers
Washer and dryer seemed to be stuck together. Hubby pulled them apart and saw what appeared to be a weld of some sort, he surmised that perhaps the dryer has a wire inside that arched (sp?), he had to force the two appliances apart. Now we worry that the dryer is a fire hazard. Would he be able to determine the cause if he removed the back and looked at the wire situation? Both are Kenmore units.
  • 63 Answers
SOURCE: G.E. electric dryer terminal block and wires are
you did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Posted on Mar 13, 2009
  • 11 Answers
SOURCE: How to seperate a Kenmore dryer from the washer under it?
This is probably a model that has two access holes at the bottom front of the dryer -about 4-5" from each side- usually closed off with plastic discs. Just an inch up from the washing machine.  Pry out the plastic discs with a flat screwdriver and you should see a screw inside each of the two openings.  Remove the screws and you will be able to tip the dryer up and slide it back a few inches to detatch from the back.
Use two people to lift the dryer down as it is bulky but not too heavy.
Posted on Oct 12, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool GEW9868K Electric Dryer remove back panel
You will need to pry the front corners of the top to open and then remove the front to get inside. Please unplug first , Thanks, Sea Breeze
Posted on Mar 29, 2009
  • 113 Answers
SOURCE: Older kenmore dryer heating problem
its probably either a thermal cut off, thermostat,and or heating element. you need an ohm meter to check each one for resistance and replace whats bad
Posted on Apr 23, 2009
  • 1253 Answers
SOURCE: AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
Posted on May 11, 2009
How do I stop light thumping noise?
For the fun of it I would pull the drum out of it and examin the bearing the drum rides on. Now some of these have a regular type wheel bearing type, and others have these wide plastic that the drum just rides on. But they are not that hard to take apart and put back together. Just need some practice.
Mar 07, 2016 | Amana ALG443RAW Gas Dryer
Replace drive belt bosch classixx dryer
worked for white knight dryers for a while and saw that the siders and main case are spot weldetd together, but dryers are really simply put together, take out more parts so you can get to what you need, but take pictures to remind you how they go back
Feb 10, 2012 | Washing Machines
Short on Jenn Air electric stovetop
Dear Genie,
Well, you are right in your surmising!
That water has shorted out perhaps as many as several items.
One way to solve this problem would be to wait until the water dries up, could take days or a couple of weeks.
Another way would be to take a hair blow dryer and dry the parts by blowing them for a while, perhaps 10 to 20 minutes, but to see if that fixed it, you would need to turn it on, which could cause a short!
No good.
Best idea is to take it all apart and see if there is visible damage, and to take and electric meter and test it all.
God bless your efforts.
Jul 10, 2017 | Jenn-Air Cooktops
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Disassemble a La Cie Porsche-design external CD burner case?
I just pulled one apart. You're not going to get it to work unless you pry it apart on the bottom. the parts are stuck together with 2 sided tape. use a thin, flat bladed screwdriver to pop it apart. i did this with relative ease, and it worked alright. didn't trash the plastic too badly either.
Dec 15, 2009 | LaCie Computers & Internet
My GE Profile Harmony Dryer purchased in DEc 2006 has had a rip in the stainless steel drum that has now reached about 2 x 3 inches large and now makes noise and does not dry properly.It appears to be...
The tear is due to a poor argon weld of the dryer drum. Check the owner's manual regarding any warranty details. Call the customer assistance line regarding this issue. Have your model and serial number ready for them to assist you. The tear in the drum is causing the blower on the dryer to pull air thru the tear in the drum instead of thru the rear inlet duct which draws the heat into the dryer. This results in abnormally long dry times due to no heat passing thru the drum.
Aug 19, 2009 | GE Profile Harmony DPGT750EC Electric...
Horrible noise and burning smell when dryer is on
Same thing happened to us, the noise is one of your wheel bearings are going bad, (they are just a small piece of plastic rollers) and the smell is your belt. The dryer is dismantled from the front. I figured out how to take my dryer apart from google. Also, you may need some help to pull out the drum wheel and pay attention to how it came out. I ordered parts from repairclinic.com and it was very inexpensive and the parts took 3 days to come to me ( I wouldn't pay for faster shipping).
Good luck, you won't believe how uncomplex your dryer really is.
Jun 06, 2009 | Kenmore 62602 Electric Dryer
Kenmore stackable washer/dryer - problem with dryer.... It was still working BUT seemed some metal had come loose in the back by the heat coil, lots of scraping noise and sparks.....so we unplugged and...
It appears your blower/impeller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 19, 2009 | Kenmore 98702 Stacked Washer/Dryer
Can't remove back of Kenmore 66901
believe that model has lower front panel remove it ..clips each side top edge press them down pull panel off ..element ,fuses thermostat behind it
Nov 18, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
93 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
