I need dgidntcp.exe file - Computers & Internet
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
Tip
Renaming The Start Button:
To rename the start button, you will need a hex editor.
My preference is UltraEdit
Copy the \windows\explore.exe file to a new name (e.g. explorer_1.exe)
With the hex editor, open that file and go to offset 412b6
You will see the word start with blanks between each letter
Edit it be any 5 characters or less
Save the file
Boot to DOS
Copy the existing c:\windows\explorer.exe to explorer.org
Copy explorer_1.exe to explorer.exe
You will also need to replace the explorer.exe in the c:\windows\system32\dllcache file as well with the new one.
Note: If the partition is NTFS and you can't access the files from DOS:
Start Regedit
Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon.
Change the value of Shell from Explorer.exe to explorer_1.exe
on Mar 07, 2008 | Microsoft Windows Vista Ultimate Edition
Dmwu.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
All you have to do is click on the start button, go to search, then type in dmwu.exe and search all files and folders. Then simply drag any matching files to the recycle bin. *NOTE* if you had the same thing as me then you have to click away the message before it will let you delete one file.
Sep 20, 2012 | Computers & Internet
Worm.autoit virus(mgy.exe) make folder and all of my data files add extension .exe.exe.exe(example: desktop.ini.exe.exe.exe, mydata.xls.exe.exe, after cleaning and delete this all, my data and same file...
Boot from a Linux Live-CD and recover your files - Linux ignores the extensions so if your files are still there then they will be clearly visible.
Jul 05, 2010 | Computers & Internet
I think i have a worm on my pc. my folders are duplicating with a .exe. pls help
TRY RUNNING SUPERANTISPYWARE i have used this program it works very well for removal of all varients and other little pesky varmint on your pc.
Jan 26, 2010 | ASUS Eee 4G Notebook
WANT TO DOWNLOAD ALL THE DRIVERS FOR COMPAQ CQ40 144-TU
Go to the following URl and you can download all of the drivers that you need:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3815422&lang=en
These are for the Vista Operating System the 32 bit version. If you are using the 64 bit version you can click on the link of that page to go where you need to find the correct drivers.
Sep 21, 2009 | Compaq Presario Notebook
Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
May 11, 2009 | Microsoft Windows XP Media Center Edition...
I want to change start button name
Renaming the Start button needs a few steps (Source: http://www.onecomputerguy.com/windowsxp_tips.htm)
Renaming the Start Button
  1. Copy the \windows\explore.exe file to a new name (e.g. explorer_1.exe)
  2. With the hex editor, open that file and go to offset 412b6
  3. You will see the word start with blanks between each letter
  4. Edit it be any 5 characters or less
  5. Save the file
  6. Boot to DOS
  7. Copy the existing c:\windows\explorer.exe to explorer.org
  8. Copy explorer_1.exe to explorer.exe
  9. You will also need to replace the explorer.exe in the c:\windows\system32\dllcache file as well with the new one.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon.
  3. Change the value of Shell from Explorer.exe to explorer_1.exe
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 03, 2009 | Microsoft Windows Xp Home Edition English...
Internet Explorer problem
Step 1: Use Windows File Search Tool to Find msas2009.exe Path Go to Start > Search > All Files or Folders.
  1. In the "All or part of the the file name" section, type in "msas2009.exe" file name(s).
  2. To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
  3. When Windows finishes your search, hover over the "In Folder" of "msas2009.exe", highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because you'll need the file path to delete msas2009.exe in the following manual removal steps.
Step 2: Use Windows Task Manager to Remove msas2009.exe Processes
  1. To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
  2. Click on the "Image Name" button to search for "msas2009.exe" process by name.
  3. Select the "msas2009.exe" process and click on the "End Process" button to kill it.
Step 3: Detect and Delete Other msas2009.exe Files
  1. To open the Windows Command Prompt, go to Start > Run > cmd and then press the "OK" button.
  2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
  3. To change directory, type in "cd name_of_the_folder".
  4. Once you have the file you're looking for type in del "name_of_the_file".
  5. To delete a file in folder, type in "del name_of_the_file".
  6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
  7. Select the "msas2009.exe" process and click on the "End Process" button to kill it.
MSAS2009 IS SPYWARE!
good luck!
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
