Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a Hayward gas heater that is flashing the code 1016-400 four times on the LED panel. Can you tell me what this means?
  • 246 Answers
SOURCE: Hayward heater attached to a 2PSI natural gas regulator
or change the heater. have you clean the burners
Posted on Sep 11, 2009
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
  • 760 Answers
SOURCE: Our Hayward gas heater keeps giving us a H5 error
Could the Error code be HS? That is high temperature limit. Perhaps you' don't have enough flow, allowing the heater to heat the water to a temperature higher, than the thermostat setting. Make sure your bypass valve is closed, allowing full flow through the heater. Check your filter pressure differential , and skimmer baskets.
You didn't give your model number, and there are many models. You can go the Hayward website below and select your exact model number and download the manual. The manual will explain each error code.
  • 990 Answers
SOURCE: buying a pool heater. Which brand best reliability
Both of those heaters are fine I prefer the Pentair for it's smaller footprint and ease of installation as you can turn it for access to plumbing. The Hayward is tougher to turn the exchanger on and you only have right or left as options for the plumbing to come out. Sta-Rite is still my favorite for installation being easy to plumb, wire and run gas to. It's very easy to change from natural to LP also.
Most heaters today are the same in reliablity and that is mostly up to you to keep the chemicals correct. Being in the business I always look to ease of install and access for repair.
Posted on Oct 17, 2010
Testimonial: "Thanks for info from an expert. Think I will get a pentair as they are sold in UT. Wholesaler doesn't even carry Hayward. So Techs aren't used to. "
What does code GVO mean
gas valve open probably stuck
Jun 14, 2014 | Hayward Pool & Spa
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Diagnose Ignition Control Module
means unit tried to fire 3 times then locked out turn off then turn back on check ignitor
Feb 07, 2018 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
Code 991 continues to show.. will not clear... how do we clear that code???
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
Jan 17, 2011 | RTO Takagi T-M1 Mobius Gas Tankless Water...
What does a Ignition Lockout (red LED blinking 3 times) mean?
The flashing light is the service code telling Joe blow that there is something wrong. As you didn't tell me the brand of car I can't tell you what that code means. Some cars will trip out a code based on milage. ( Company Scam ),
Please reask with more details. THX Ash.
Jun 20, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
We got a hayward h200 seriers, don't know if it is propane or gas
The p in the model means propane and you should also see a sticker on the gas valve that also says propane on it.
Jul 18, 2009 | Hayward H Series Pool & Spa Heater 200k...
Cannot tell where pilot, on or off is on gas valve
I assume you have a W-R and should see a small notch down around 5 o'clock or so. That position is where you depress the knob to light the pilot.
Jul 03, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
91 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
