Question about Whirlpool Calypso GVW9959K Top Load Washer
When I press one of the cycle buttons to start the washer, "FL" shows up on the display screen and the washer just beeps until I press cancel. What does that mean?
  • 2,382 Answers
Hi, you have a flood code. My neighbour is on pump # 3 with his 6 year old Calypso. Fibers and lint get tangled in the pump causing failure. You must replace both motor and pump now sold as a one piece unit. Part # 285990. Go to Appliancepartsoutlet.com for $88.95. Everyone else is $109 for same part. You have to access from underneath the machine. Move away from the wall far enough so you can tip the machine to rest on the wall and steady it with some blocks of wood so it doesn't fall on you while you are underneath it. Drop the bottom plate to the see area you'll have to work on. Drain the machine by unclamping the two pressure clamps attatched to the pump and be ready to collect about 3-4 gallons of water in a shallow pan. A wet vacuum , rags , and a helper won't hurt. Drop motor by removing 3 screws and unhooking the electrical harness clamp. Install new part and reconnect everything and your good to go.
Posted on Oct 02, 2010
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine keeps beeping when i try to start it and it goes from the minutes on the screen to do to FL ?? ive tried turning it of and restarting it ?
Hello there: FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. You may want to have the water level sensor replaced cause this will cause this condition if it is faulty ok
Hope this is very helpful for you
Best regards mike
Jul 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
MY WASHER IS BEEP AND DISPLAY FL
FL means flood condition
Solution: "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Jul 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Every wash cycle FL shows on the screen, I have to extend the spin cycle to get all of the water out.
FL
Flood condition
Check the over fill switch hose for weakness or, damage if the FL code continues. if the hose is ok, replace the Over fill switch..
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GOING NUTS WITH WASHER
FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso with an error code of FL. where do I find the switch to reset the washer
"FL" (Over Fill) flashes
The washer will beep every 10 seconds with no time-out, The
faucets to the inlet hoses if water continues to flow,
If it still happens you need to get a service guy out.
Dec 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Hotpoint wf865 problem
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Pl rate me nice if this solution helped!
Mar 22, 2008 | Hotpoint Ultima WF865 Front Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
356 people viewed this question
Dan Webster
Dan Webster
Sal De
