Question about Vacuums
I have a shark sc630 pocket steamer that supposed to steam clean microwaves so far No Steam will come Out of it at All it Heats up but No Steam Will Come Out Why? Please Help
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
SOURCE: Shark floor steamer: Does not
I don't how to fix the broken one but have been told by others to use distilled water in a replacement it should last a lot longer.
**** McLaughlin
Lincolnville, Me 04849
Posted on Feb 17, 2009
evbob
  • 8 Answers
SOURCE: shark steam mop
Well got one brought it home worked for five minutes. Went back to walmart exchanged my Shark.Only one box left,looked opened but nothing seemed out of place till I got it home.Must have beeen a previous return somebody was short a funnel for their meth.lab(lol).Now warranty or not have tod to take it apart and see.There is a line that looks like it has a tendency to come off it has a spring inside it.Looks like it just blew apart because of pressure (poor design) Going to reattach it see what happens.
Posted on Jun 13, 2009
satch498
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
SOURCE: Euro Pro Shark Steamer #S3325. Will not steam
Have you tried CLR?
Posted on Aug 11, 2009
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
It heats water inside the machine, but won't steam
contact Shark . they will know better and faster than we could find it .
Oct 20, 2015 | Shark S3501 Steam Pocket Floor Mop With 5...
Shark steamer leaves the floors streaky
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems
heatman101
Feb 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi, My Shark Pocket Mop steamer isn't getting steam to the head, and when I removed the head I found that there is calcium build up on the opening of the body. What is the best waytto remove it? gnc
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Jan 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Shark Steamer heats up and the light is on but I cannot get hot steam to come out any longer ?
heatman101
Dec 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The Shark Steamer stopped steaming. Can I fix it
heatman101
Nov 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a shark steamer and steam comes out, but it is not hot. i can literally put my hand in front of it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The steam will cool very rapidly and it is possible that yes you can place your hand in front of it... if it wasn't a steam vapor it would not spray out....
The heating element may have died or there is an obstruction...
heatman101
Aug 21, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a shark steamer, light is on but no steam. ...
Nope...no cleaning to it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
124 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
