Question about Kenmore 24032\24036 Top Load Washer
80 Series top loader excessive vibration and noise on spin
I have an 80 series, model no. 92579110 that makes excessive noise and vibration on spin. There is enough vibration to move the unit. when i put any downward pressure on the unit or lean on it seems to work as it should. Help!
  • Anonymous Jun 05, 2008
    wahing machine basket spins very rough, making loud noise . spin basket cannot stay in position. what should i do?
  • 550 Answers
Check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
Posted on Jun 04, 2008
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 Series top load washing machine started making a LOUD rhythmic banging noise during the rinse & spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Sep 30, 2010 | Kenmore 24032\24036 Top Load Washer
Vibrates, shakes and moves around and has a lot of noise while spinning. It has been leveled and the floor seems sturdy enough.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Excessive vibration in spin cycle
Be sure the washer is on a solid surface, no plywood or skid platforms. Then be sure to lock in the front levelling legs.
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 BALANCING PROBLEMS
Wiz, That black piece of foam is just a sound dampening strap, no big deal. This is a hard one, I see a lot of these vibrate when there is a false floor. Here are some things to check: makes sure the front legs are locked with the nut. Check to see that all the springs are attached and the plate is centered, I will attach a photo. Depending on whether the machine is walking or just the tub banging, it could be the drive block for the basket. You will have to remove the cabinet or tip it back to check the springs. Catriverdf505ed.jpg
Jan 28, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
231 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
