Question about Briel ED271AP 10-Cup Multi-Pro Espresso / Coffee
Is Rancilio Silvia best for $400?
My wife and I have owned 3 pump machines over the past 15 years or so (El Expresso and 2 Krups). I am ready to move up to something about $400, and would appreciate some advice. We use it every day, and make about 4 large caps. The Rancilio Sivia looks good. Opinions? Best sources? Amazon.com has one called the Briel multi pro for the same money. Thank you. I have the Briel Multi Pro and it has never made satifactory espresso. It doesn't seem like the water gets hot enough and doesn't have enough pressure. My husband and I have just been making two cups of strong coffee and then frothing milk to make a latte.
    Novelist:
  • 137 Answers
Yes, you can get better quality from Rancilio silvia, if you try to get the maximum from it. i believe that in short tame you will be able to do it.
in the video she uses the machine but im not content about one detail, i give solution there.
video :
http://www.fixya.com/support/t422860-making_cappuccino_rancilio_silvia
Posted on Mar 30, 2009
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
My Rancilio Silvia won't pump water out of the head all of a sudden. It had worked for years up to this point
It may be that the 'shower screen' which is a perforated metal disk filter that fits inside the head has reached its use by date.
These can be found and bought on E-bay for about $15 each, make sure you buy a genuine Rancilio replacement, while you are at it, replace the rubber 'group seal' - a rubber ring for pressure sealing the head/arm after filling the arm with grounds - these are a similar price. If you get leaks around the head while making a coffee, the seal is worn out.
Jul 31, 2013 | Rancilio Silvia Espresso Machine
Pump won't turn off on my Rancilio Silvia. I left machine on for about 1 1/2 hours, then brewed the expresso and when I tried to turn off the pump switch, it didn't go off. Now every time I turn on the...
The pump switch is either burned out, shorted out, or there is a CPU problem. You will need somebody local to do basic electrical troubleshooting on this machine.
Jan 23, 2011 | Rancilio Silvia Espresso Machine
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancillio Expresso Machine won't pump water through. Makes lound noise.
Hi There are a couple of things. 1. Your pump is not primed. Open the steam knob and push the middle switch. 2. Your intake hose is pinched or not connected to the pump, or your intake hose is not in the water tank.
Feb 21, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Briel ED271AP 10-Cup Multi-Pro Espresso / Coffee Logo
116 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Dennis Fitzsimmons
Level 1 Expert
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
