Question about GE Heating & Cooling
I bought a window a/c 115volts 12000 btu today i finished the installation 1 hour ago the unit is cycling on/off but is not cooling because is cycling on/off ?what i am supposed to dm
  • 20 Answers
If you are running the air conditioner with a extension cord it will most likely cycle but the compressor wont start ,or the outlet where you have it pluged in to is not a dedicaded line the same will happen let me know how it went
Posted on May 27, 2008
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Tempstar 5000
    The 48 before the VKD in the model number stands for 48000, BTU. For refrigeration, 1 Ton = 12000 BTU. Therefore 48000 BTU / 12000 (1 Ton) = 4 Tons
    May 03, 2013 | Heating & Cooling
    I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
    that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
    So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
    In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
    However, if you try to cool a 800 sq ft room - it will not work as well.
    Hope this has helped.
    Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
    Jus need to know if my unit is a 2.5 ton as the installer told me
    Do you know the BTU of the unit . approxmently 12000 BTU = 1 ton of cooling
    Jul 18, 2011 | Goodman Heating & Cooling
    How many tons is my unit?
    divide your btu rating by 12000. (1 ton = 12000 btu)
    For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
    A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
    you can find out your btu rating by looking on the tag on your unit.
    Jun 07, 2011 | Heating & Cooling
    My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
    The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
    A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
    So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
    If it's not well insulated you will need 24,000 btu.
    Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
    The unit is not cooling the room. It is only comforting when you are in direct line of it.
    you need to find out the size of the unit.
    Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
    So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
    If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
    Jun 06, 2011 | Samsung AW0603B Air Conditioner
    How much area can 1hp of this brand can cool
    the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
    if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
    note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
    take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
    fyi - it doesn't matter what 'brand' - they all work off the same principle.
    hope this helps
    Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
    Will not cool
    I bought the same unit yesterday and took it back today. Not sure what's wrong, I guess they are junky a/c's.
    Jun 10, 2008 | Danby Portable Air Conditioner
    Heating & Cooling Logo
    47 people viewed this question
    Top GE Heating & Cooling Experts
    ray gallant
    Jay Plesset
    Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
