Question about Samsung YP-55 MP3 Player
Hola no puedo formatear mi yp u2j no me abre en ningun computador. gracias
pseudonym
  • 15 Answers
SOURCE: samsung yp-u2j shuffle
Set the User Button Mode to and press the [ USER/ ] button. Playback mode changes in the following order each time the button is pressed . Hope this helps.
Posted on Sep 02, 2007
SOURCE: yp-u2j
My samsung yp-u2j is not connecting, its realy pissing me off, because my cumputed wont download the new hardware i need...
Posted on Jan 16, 2008
creeperz
  • 52 Answers
SOURCE: YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Posted on Mar 14, 2008
SOURCE: PROBLEMAS CON MI SAMSUNG YP-U2J
YP u2 J is only audio player? Can it be used to store pictures from pc and tranfer them to digital picture frame?
Posted on Sep 10, 2008
SOURCE: i can't my samsung yp-u2j in my pc an i already
You need to upgrade your player’s firmware if you experience any of the following:
  • When your attempt to use the player, the Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
  • The player constantly appears and disappears in Device Manager or appears in Device Manager with an exclamation point indicating an error.
  • Your computer sounds the connecting and disconnecting chime when you connect the player to the USB port.
  • The player does not appear in My Computer.
  • Uninstalling Windows Media Player 11 and using Windows Media Player 10 corrects the issue.
  • When you use the player on another PC or laptop, it works flawlessly.
  • Your player was working properly with Windows Media Player 10, but you’ve recently upgraded to Windows Media Player 11 and your computer no longer detects it.
  • Go to Samsung.com, enter in the model u have in the search area and then go to support, this should fix the problem!
Posted on Jun 05, 2010
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Como desbloquear la region de mi DVD DV556
1) Enciende el equipo sin ningun disco adentro
2) Espera a que te muestre el mensaje de "No disc"
3) Abre la bandeja donde se ponen los DVD
4) Presiona tres veces el numero 0 en el control remoto (i.e.: 0 0 0)
5) Se te mostrara un pantalla con el codigo de la region que tiene el aparato
6) Presiona 0 para cambiarlo a multiregion
7) Presiona el boton de Pausa en el control remoto para confirmar
8) Cierra la bandeja
9) Apaga el equipo.
Nov 22, 2010 | LG Televison & Video
Hola donde puedo conseguir el manual del receiver
Hola! Puedes buscar un manual por tu radio en el website de Kenwood por supporte.
Solo necesitas a buscar tu numero del modelo de tu radio y puedes copiar el manual ...no cuesta nada... checkas AQUI
May 30, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Hellow! I need to make a questions in spanish. Mi mp3 graba en archivos .act. cuando los paso a la PC no los puedo escuchar. Solo puedo hacerlo en el dispositivo. Como pueo escucharlos en la PC?? Muchas...
Hola gracias por usar fixya.com
Si no puedes escuchar los archivos de mp3 en tu computadoras es porque te falta el player. Hay muchos players gratias como windows media playar or itunes. Para bajarlo ve a www.itunes.com
Gracias
May 21, 2010 | Clarion DB365USB CD/MP3 Player w/USB
Bateria camara digital Polaroid T737
Mi español no es muy bueno, yo espera que puedo ayudarle. Encontré un Web site que tiene la batería para su cámara.
chasque aquí
Jul 27, 2009 | Polaroid T737 Digital Camera
En la pantalla aparece set 1 no funciona el control remoto
Presionar ENTER y el boton numerado 1 (por SET 1, 2 por SET 2, 3 por SET 3) por mas de dos segundos.
Mar 02, 2009 | Panasonic DMRES15 DVD Recorder
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
Como Programar mi tv Sylvania?
tengo 1 control steren modelo RM-8000 y no puedo programarlo en mi tv sylvania. ¿que puedo hacer?
Sep 07, 2008 | GE RM24912 Universal Remote Control
Tengo problemas con mi pc no tiene sonido ¿ que puedo hacer
mi pece no tiene sonido
no tiene los driver de la targeta
Jul 15, 2008 | M-Audio Computers & Internet
Samsung YP-55 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
