Question about Peavey ValveKing VK112 50W Combo Amplifier
Will not power up. I turn on the power and stand-by switches and get nothing. I don't think it's the transformer since the was no "burn" smell when it went out and I tried replacing the external fuse to no avail. There are 3 internal fuses so I was wondering if that could be it. Recently did a tube swap for JJ teslas. Switched back to original tubes when the amp went out and still nothing. Please help. I love this amp....
  • 5603 Answers
SOURCE: Amp will not turn on.Fuse and tubes are in good
Likely a bad power switch, or possibly a broken power cord.
Rarely a fuse holder or transformer go bad.
Posted on Sep 02, 2009
  • 5603 Answers
SOURCE: No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Posted on Sep 28, 2009
SOURCE: Hi, My Peavey Classic 50/50 has power (leds are
I had checked the fuse for the heater circuit and found that while it was testing on a low ohm check meter - it was not sufficiently handling the
full demand of the circuit - I put a bypass on the fuse and found the problem. The fuse appears to have been previously replaced with
a type not original - the original was a ceramic case fuse 10A.
I appear to be operational
MB
Posted on Dec 28, 2009
  • 5603 Answers
SOURCE: I have a peavey classic 20 guitar amp that works
What do you mean they "switch off"??? If the heaters in all the tubes go out, check the fuse for the heaters, F2 and its fuse clips/holder.
There really is nothing in the circuit to make them "switch off"
If the heaters in the EL34's "switch off", the other tubes should go out as well.
Posted on Jan 25, 2010
  • 5603 Answers
SOURCE: My amp stopped working after 2 days from the day
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Posted on Nov 29, 2010
I have a FC10 Yamaha organ and the off and on switch won't switch off. There is a strong burning smell. Can it be fixed
There is a component failure, probably the switch itself, but it may be other parts in that area as well. Do not turn it on again before it's fixed for risk of fire.
Sep 06, 2016 | Yamaha Music
I have a Mackie 406m powered mixer. I was in a club with less than adequate power. My mixer got very hot and started smelling. Now when I turn it on, over 6 months later, it still smells and it has a loud...
More in likely a voltage drop in the club, and the mixers power transformer was fighting for power, so it's brunt or burning up, also there are capacitors that filter the AC transformer hum, they Probably need to be replaced, this can be fixed tho, parts and labor might not be cheap...
Mar 05, 2015 | Mackie Music
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Transformer broken 3 times!!! nothing strange, do not move or fell or connect to other things, use it only one time and burned !!!??
I assume you are using OFFICIAL Moog transformer. This takes a 12 VAC 500ma trnasformer which is VERY uncommon for pedals. DO NOT use the common transformers for most pedals which are around 9VDC as they MAY appear to work briefly but will not operate this unit. Let me know what Moog model power transformer you are using.
Jul 26, 2011 | Moog MP 201 CV/MIDI Control Multi Pedal
Hello, I have a Mackie 1604 VLZ Pro from 1995. It's 110 volts and I want to change it to 220 volts. Do I need to buy a new transformer? I don't want to us an external step-down...
The LEAST expensive thing to do is to buy an external stepdown transformer.
Here is a link:
http://www.world-import.com/transformers.htm
The 100 Watt would be adequate... If you think you might need more you could have a reserve for other equipment... At around $8 USD I don't think you can beat that. The labor cost to change the internal transformer would cost many times what the external transformer costs, not to mention the cost on a new internal transformer.
Jul 24, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I plugged what i assumed was the correct transformer into my micro br and after a burning smell it died .obviously now i realise it was the wrong one ! unit does power on by battery still and works ok .is...
This was probably supposed to have a 5 volt power adapter... you burned up either:
1. Regulator
2. Circuit trace on the board
3. Protection diode
4. resistor ahead of the regulator.
Repair should not be too bad if they know exactly what you had connected, Make sure to use a competent shop.
May 06, 2011 | Roland Boss Micro BR Multi Track Recorder
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
Amp lost power and smelled like something was burning
You'll have to remove the amplifier section from the speaker cabinet and look inside the chassis.
Check the power transformer, the output transformer and the rectifier, see if any of these shows signs of overheating.
Jul 14, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Peavey ValveKing VK112 50W Combo Amplifier Logo
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
