Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a Water ACE RV5, 1/2hp. It is no more than 2 months old. Worked great when I first got it, but now, it pumps with 1/2 the strength. In wet weather, as water trickles in, the float will not get low enough to turn the pump off. I have cleaned it out...it looks new (inside and out). I have ruled out check valves, float switch, impeller...how do I fix a motor problem?
  • 17 Answers
SOURCE: New water ace sump pump will run but willnot shut off
The higher you pump the water, the stronger your pump needs to be, or the skinnier your hose needs to be. A lower discharge point and / or a smaller diameter hose might help immensely.
Posted on Mar 05, 2009
  • 32 Answers
SOURCE: I have a brand new 1hp water ace water pump
If it was initally wired for 230, I question who rewired it for 115, the reason is 230 is a foreign relation in the metric world, 220 in our world, in which case two of the wires wires hooked up according to non American standards. The scamatic showed the change over inside the cap, but in china the white is the ground and the green is reversed with the red to make the motor in reverse, confused, you should be, cause I'm not looking at the motor so there is no way for me to know what you have there! What I'm saying is stop before you burn up the motor and take it to a motor shop that knows about the proper rewiring to change it from 220 to 110. 4 Min. is a long time, you may have already fried it. Good Luck!
Posted on Jul 18, 2009
  • 548 Answers
SOURCE: Damaged plug on end of float switch
if it is just a small length of cord you can just attach any cord to it from any old appliance, if you feel that it needs to be waterproofed go to home depot and by one for wet areas
Posted on Sep 18, 2009
mkh5094
  • 145 Answers
SOURCE: just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
Posted on May 28, 2010
  • 257 Answers
SOURCE: I cant find vertical float
www.ereplacementparts.com is the most complete place I have found
Posted on Mar 07, 2011
Unit is not collecting water and carpet is wet
Unplug it and let it dry out. Place it on old newspaper and start. Check the paper and look for the wet spot. That will let you know where the water is coming out of the unit. Check that area, it is probably a bad seal on the drain or a crack in the water container.
Feb 16, 2014 | Whirlpool AD50USL Dehumidifier
The washer does not spin all the water out ,clothes remain quite wet
is your pump blocked? sometimes hair clips or money etc get stuck in the pump and stop it pumping effectively.
Jun 18, 2012 | Washing Machines
My battery alarm keeps beeping. The system is less than 3 months old (Including battery) The battery terminals are not corroded at all. It is plugged in at all times. What can I try to fix this?
You really need instructions to understand this system. I know that on some units, there is a water level probe that alarms. Does the battery need distilled water?
Also in some cases, if the unit has operated because the main pump failed, it will alarm to let you know to fix the main pump. Push the reset button & hold it for 10 seconds to reset that alarm.
Do you have trouble lights & an explanation? If not on the battery, check your instructions.
Gary
Sep 19, 2011 | Ace Hardware Ace& Battery Back-Up Sump...
The Ace water pump (Less than 2 months old) suddenly quit working. No weird noise or anything. What can be the problem? What can we do to test it?
To test the unit: You need to remove the unit from the power source and measure it with a multimeter (on the OHMS range). If you get an open circuit reading, then either a safety sensor has operated (removing power) or the pump motor is defective.
At 2 months, it should still be under warranty.
Manuals at: http://www.waterace.com/manuals.html
You might have to call 1-800-942-3343 for further assistance.
Jun 05, 2011 | Hardware & Accessories
Will drain water
110-120v motors are designed to run only one direction they cannot be reversed a more likely solution is that something is blocking the line for water to flow out or that the impeller is not turning try taking the hose off the top (be careful not to get wet ) and turn the pump on to see if water comes out top if it does line is blocked, if not time to get new pump
Sep 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Sep 18, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a 1 hp ace pump on a 30 gallon bladder tank the pressure switch keeps clicking off and on until the switch burns up have replaced 4 times in 2 months have adjusted switch until pressure is very low...
There are tow screw adjustments on the switch. One is the high shut off and the other is 'differential'. This is the one you need to adjust. It gives the 'window' that the system needs 'between' on and off.
Aug 30, 2009 | ACE JET PUMP For shallow well
1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Jul 18, 2009 | Plumbing
Cloths are still very heavy and wet
Sounds like a pump problem or a kinked drain hose. The machine cannot spin or spin properly until the pumps gets the water out of the tub.
Sometimes the drain hose get plugged or kinked and won't allow the water to be pumped out so make sure that is not an issue. But, I'm more inclined to believe this is a pump problem.
Dec 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
165 people viewed this question
Top Water Electrical Supplies Experts
Lawrence Oravetz
Ottoniel
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
