Question about Jenn-Air Kitchen Ranges
Jenn-Air dual-fuel range model SVD48600B dislpay (clock/temp/etc) is too dim to read. Do we need new display unit or perhaps a power supply board?
  • Jenn-Air Master
  • 2,699 Answers
You need to change out the clock assy. part number 71001799 and it's around 200 bucks
Posted on Oct 02, 2010
  • mfmedford
    mfmedford Nov 16, 2012
    Is this a DIY or do I need a repairman?
  • Sal De Nov 21, 2012
    sorry to get back to you so late,if you're good with your hands you should be able to handle it.unplug the machine before you work on it,take a picture of wires or anything you think could be a problem but it's basic stuff.
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
My Jenn Air Dual fuel slide in Range (2003) Mdl JDS9860AAB Resets itself as if it had lost AC power. This happens about once a week. or if I am cooking an important meal (like Thankgiving) It resets itself...
Main micro-processor, clock control defective, replace clock control or it power supply board. It's recommended to replace power supply & control if this unit has the two on seperate boards.
Sep 30, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
Jenn aire oven no power.
go to jenn air web site -find your stove model number and find user & care guide that should help you
Mar 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Clock display board
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Apr 11, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Display blank
Every time I have seen this problem, it has been a bad display assembly. These are fairly easy to change yourself, but the part is kind of expensive, I think in the $150-$200 range. Hope this helps!
Aug 21, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
515 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
