Question about Kenmore Elite HE5t Washer
Ls there any way to clean or temporarily repair the analog pressure sensor on the kenmore elite washer with an F35 error? We have been without use of washer for 2 weeks and are told at least another 2 weeks before part comes in.
  • 2,382 Answers
Hi, the error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It costs about $99 to order from Sears although they are on backlog, or you can get it cheaper somewhere else. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected.
Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires & 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor - takes a little playing with to remove the old one & the wires. Replace lid and works like new!
Posted on Oct 02, 2010
HOW TO FIX A F 35 ERROR CODE
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. If you are not completely confident in your technical ability to safely access and check these components, I recommend calling a service technician to diagnose and repair the washer.
Aug 13, 2014 | Kenmore Washing Machines
F35
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. Here is the pressure sensor you can order.
Oct 27, 2012 | Kenmore Elite HE5t Washer
What means Error code F35 on Kenmore Elite washer
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
I suggest check:
- Check if pressure hose is fi xed correctly.
- Check if the airtrap is not blocked.
- Check if the hose is not blocked.
The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below... image56387img-or.jpg
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 14, 2011 | Kenmore Washing Machines
Kenmore elite he 3t model# 110 46747801 blinking sud and then f35
Hello, welcome to FixYa.
The F35 error code (can also be associated to the "Sd" or suds error) on most not all ...Whirlpool built front load washers indicates the control has detected an analog pressure sensor (also commonly known as a wter pressure switch) error.
Whether the sensor is faulty or not remains to be seen, here's what to check first.
**Unplug the washer from the wall before servicing...safety first**
This error "F35", can be caused by the air pressure tube being blocked or kinked between the bottom of the washer tub and the analog pressure sensor, examine by removing the top and back panels and inspect the hose and dome, i.e.
If you find a blockage, kink, cut/torn hose or loose connection in tube, then this is the likely cause the error. If it however appears okay, then you will likely need to replace the analog pressure sensor, i.e.
As I alluded to though, make sure the hose is clear and not cut and the air-dome at the tub isn't plugged and if not you'll have to replace the switch.
Let me know how you make out and I'll help further in any manner I can. Good luck.
Regards,
Macmarkus :)
Jul 27, 2011 | Kenmore Elite 45986 Front Load Washer
Receiving code F35
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
I am getting both the SUDS and F35 errors on my Kenmore Elite HE3t steam washer. How can I check the drain filter to clear any debris or build up?
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Jun 03, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 46742 washer will not wash. It starts to fill and then SUDS or F35 appears on screen. It will not move through the cycle.
Jan 23, 2011 | Kenmore Front Load Washer
My Kenmore Elite comes up with F35 not sure what that means and locks my machine up
Hi
In your Kenmore F35 error indicates Analog Pressure Sensor Failure. To resolve this issue you have to start with checking the pressure hose and the air trap, try to clean them for any clogs and check if they are fixed correctly. After doing this if the issue is still not resolved then you'll have to check and replace the water level switch.
Thanks
Rylee
Oct 29, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F35
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer. I am not aware of other uses of the F35 code on the various models. If you intend to diagnose and repair this problem yourself, I recommend resubmitting your question with the full model number of your Kenmore washer so that we can verify this technical information using your model number.
Jun 08, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE5t Washer Logo
179 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
