Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I just purchased a used 51. it looks almost new. thought i got a good deal until i used it for about 10 minutes. it started to run sluggish as if i was running out of gas and than it stalled. i tried to restarted it immediatedly and it would not start up. i set it down and went to get my other husky saw. after i was done cutting for the day i tried to start the 51 again. it started right up. so i proceeded to cut some wood and try it out again. after about 10 minutes it did the same thing. seems to run fine until it warms up. then it gets sluggish and quits on me. i have been using husky saws for almost 20 years and i never had problems with them. i would like and try to fix it myself. can u help me/
With small 2 stroke engines, it's either a spark problem or it's a fuel problem. In your case, it's definitely a fuel problem.
It could be you have a drop or two of water in your fuel or in the carburetor. Put a bit of HEET (methanol) in your premix, it'll take a while to dry it out if this is it.
Check the air cleaner element. If it's dirty, clean it with carb cleaner or gasoline or similar. If it's missing entirely, this is likely the problem, it won't run properly without a filter element, as it requires a slight drop in pressure to create a vacuum to **** fuel out of the carburetor.
Also check the fuel line for a gap or crack. Either will cause it to do what you're describing.
If you still didn't get a hit, take the carburetor off and carefully clean it. It doesn't take much of anything foreign to make it wig out.
Hope this helps.
Posted on Oct 02, 2010
Need to purchase the projection mirrot for KP-51HW40
I suggest you call local repair shops and see if they have replacement parts for that model. Sometimes you can get a good deal on a used mirror which is just as good as a new mirror. Your set was a very popular model so chances are good for finding replacement parts locally. Good luck, Russmann.
Aug 17, 2010 | Sony KP-51HW40 51" Rear Projection...
I couldn't take my brand new vehicle home cause it wouldn't start
you should talk with an atturny and not acc the jeep or at least have a good amount nocked off
Mar 23, 2010 | JEEP Wrangler Unlimited Toy Vehicle
1991 Honda 750 Nighthawk...been running great. Hadn't ridden it much last 30 days or so...got on it tonight, noticed a sluggish throttle. Initially, there was slight black smoke coming from the exhaust....
carb. needs to be rebuilt sounds like trash in the float body or in the needles try using some sea foam in the gas tank (if u get it to start again) it has probably fouled out the plugs
Nov 02, 2009 | 1992 Honda CB 750 Nighthawk
Used to flicker, now dead
You possibly need to replace either the Main board, or the power board, they both can be purchased online, and you can either install yourself or go to a site like Onforce.com and accept bids.
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
New TB70SS used one hour run great started easy. Following week started on run fine for 10 minutes it became sluggish and died. Has not started since. Yes new gas correct mix. check spark arrester for...
If the trimmer is new and giving you these problems, then take it back to the retailer and either trade for another one, or pay a little extra for a 4 cycle. The 4 cycle is a little hard to start too, but will run out perfectly and no more mixing of oil.
The higher price tag is well worth the time, effort and aggrivation experienced versus a 2 cycle engine.
I hope this helps.
Jul 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Hitachi 18v recip saw just quits.....battery life or saw problem?
You are ok with what you got. The cordless saws take a lot of power to cut wood so it drains the battery fast. I have the ridged setup and my battery on a full charge only gets 4 cuts on a 2x4 befor it is dead. The saws will not give you any worning becauase the teath of the blade will get stuck in the wood so it just will not slow down like the drill will. I hope this helps with your ?
Dec 31, 2008 | Hitachi 18V Lithium Ion Cordless Hammer...
Husqvarna 359 Low speed running
A lot of 2 cycle engines do not run very well if they have been put up for a long period, (say for winter) with gas in the engine and carb. I finally learned the hard way that if you empty the gas tank and start the normal way and use up the fuel in the lines and carb, you don't get the residue build up from gas that has deteriorated over time.
Suggestion: empty the fuel out of the tank and run it dry by starting. g\
Get some gas stabilizer and add to fresh gas, fill the tank and run a few times. It will take awhile but you can gradually get rid of any residue build up
Hope this helps. Loringh ps Please leave a rating if appropriate Thanks
Dec 03, 2008 | Husqvarna Chain Saw 20" Bar
Casio exilim ex-z75 Battery is STUCK!
what kind of battery is it? a slim line or like AA's?
Jul 02, 2008 | Casio Exilim EX-Z750 Digital Camera
After 5 minutes of good use screen goes redish color
It certainly sounds like the Red CRT (picture tube) has heater-cathode leakage and is not likely worth repairing, as all 3 tubes usually have to be replaced at the same time for best picture quality.
Feb 10, 2007 | Sony KP-51HW40 51" Rear Projection...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
97 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
