Garden Logo
Posted on Oct 02, 2010
Performance power PCS 1200 circular saw - Garden
1 Related Answer
Anonymous
  • 15 Answers
  • Posted on Nov 18, 2008
SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
Manual for PowerShot item 9000 Electric Staple & Nail Gun Mfg by PowerShot Tool Co. Inc
Track Saw vs Circular Saw-which is best for your project March 19, 2020 By pervezWe use a saw for cutting wood or any material. In the market, we can find a lot of saws and it will do our desired work. If you are a woodcutter then a track saw will help you. A track saw is a handheld circular saw, on the other hand, a circular saw is one kind of power saw which helps to cut woods or any material.We can use track saw and circular saw for cutting woods and other materials like tile, brick. But there is a difference between them. We have to know what is Track Saw vs Circular Saw. see the difference between them given below.
Track Saw vs Circular Saw Lets Have a quick look into these A user uses a saw for different cutting purposes circular saw and track saw is one of them. The track saw is used for cutting woods and circular saw also used for cutting woods too But both of them are used for different purposes.
Circular Saw
We use a circular saw for cutting woods and it uses a round blade lined sharp metal blade. A circular saw is used for cutting woods, plastic, metal, and masonry. Circular saw is an electrical saw and it runs through electricity. There are some things in a circular saw and they are-
  • An on/off switch
  • A handle and upper guard
  • A cutting blade and lower blade guard
Safety Procedure Circular saw is a powerful tool and it is dangerous too. A user must wear safety equipment while using this circular saw. Moreover, this tool can produce a lot of dust so better is use masks for it. We have to hold the saw perfectly with both hands so that it will not move from the place.
If you have enough time then you may go through the article- Top Circular saw Buying Guide.
Track Saw
The track saw is a handheld circular saw and this helps a user to cut logs accurately. A track saw can cut any log faster than a circular saw because they are lightweight and portable. The layer on a track saw creates an effective dust trap and also doesn't just enclose the blade.
The track saw is suitable in any situation because of its rubber strips at the bottom. It is easy to cut and no need for measurement and it can make a big cut into small pieces.
The Benefit of Track Saw
  • A track saw is easy to move
  • Smooth and clean cuts
  • Long meters for cutting any objects
Mainly a track is easy to move from one place to another place and it will give a user smooth and clean cuts than other saws in the market. Easy to cut no measurement needs to cut a log or any material just line it up and cut it. No guesswork or measurement is needed to cut woods.
Should a User Choose a Track or Circular Saw? A track saw and circular saw both of them these are using for cutting any material or woods or a tile or metal and plastic things. The track saw is one kind of circular saw which is portable and easy to use than a circular saw.
A circular saw is a powerful and electrical saw. The user has to be careful while using this saw because any single mistake can risk his life. So if a user loves to use a handheld saw then he should go for a track saw and if he wants a powerful saw then he should go for a circular saw.
Circular Vs TrackSaw
Track saw and circular saw both of them use a circular blade but track saw blades are less uncover. The major and main difference between them is one is easy to move another is complex to move. Another difference is track saw provides a better cut and smooth performance than a circular saw.
Circular saw creates more dust than a track saw because in a track saw a dust filter contain on it(track saw). The circular saw is best for construction purposes because it can give you the best performance than a track saw. If you are going to cut lumber or a tree on a roof than a circular saw can help you better than a track saw.
So better is if a user wants to use a portable lightweight saw than track saw is better for him. But if he wants to use a saw that provides more facility than circular saw is for him.
Final Words Both of this saw is perfect for cutting wood or any kind of material. A track saw is portable and lightweight on the other hand a circular saw is more powerful than any other saw. You can carry a track saw with you in your shoulder but can't carry a circular saw with you.
So if you want a lightweight saw then track is for you or if you want a powerful saw then circular saw is for you.
Filed Under: Guide
1helpful
Need a power cord for a porter-cable circular saw model 146
All of Porter-Cable's circular saws have model numbers starting with a 3. Assuming your saw is a 346, Porter-Cable's part number for that cord is 330079-98. If your model number isn't 346 or you can't get that part number, most any nine to twelve foot 14-2 power cord will work on your saw.
1helpful
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
1helpful
Do I have to charge battery after each use or let the battery go dead before charging
It is best not to recharge a battery with minimal use. The time to recharge is when you notice a lack of power or performance. The only time that is recommended to "TOP OFF" a battery is when you are going to put it to hard use. Let me know if you need more assistance.
2answers
Instructions or diagrams on how to replace a power cord for a makita circular saw.
here's a article on how to fix it.
http://www.amazines.com/Electronics/article_detail.cfm/78565?articleid=78565
Blown engine
makita likes you to use at least 91 octane fuel and a synthetic oil mixture. the stens oils is garbage, i switched to the makita oil around 6 months ago and i havent had a problem. also, the wacker saws use the same motor and their piston heads are sleeved in carbon so they last longer and dont score the cylinder as fast as the stock makita heads.
makita also makes a 100:1 mix hi performance oil you can use.
Oct 11, 2008 • Saws
3answers
Cordless or cord saw Comparison
Cordless tools lose power as the battery drains, while corded tools deliver reliable, consistent performance with unlimited run time. Corded reciprocating saws range from less than 5 amps to 15 amps or more, with more than 10 amps providing optimal power for heavy-duty commercial use.
Top Garden Experts
Jay Finke
Jay Finke
john h
