Question about Dell Vostro 1000 Notebook
Hi. i have a dell vostro 1000 which would not charge its batt so i bought a new batt that had no charge then charged it and it worked once. but now will not charge nor will the batt charge light stay on. when pluged in light comes on momentarily then turns off .sometimes when i unplug it for a second and plug it back in the light will come momentarily then turn off momentarily then come back on again momentarily then turn off and stay off .if i unplug it again and plug it back in and the same thing happens.also i get a message at start up that it does not recognize the a/c adapter.this is same adapter that has worked for two years and also works fine plugged in.i hope you can help.thanks
    Scholar:
  • 110 Answers
Could be many things, not necessarily in this order, but the ac adapter has gone bad(highly suspect), the power converter/charge board has gone bad, the power plug receptacle has an intermittent break in it from years of use (might be able to re-solder that one back on the board ) - or the new battery is not as new as you thought. In any event, You should send it to an authorized repair center - looking at a $100 bill or more.
Posted on Oct 02, 2010
Dell vostro unable to charge
Dead battery? Try another cord/charger.
Dec 28, 2012 | Dell Vostro 1000
I put my Dell Vostro 1000 laptop on charge and click the power button for it to turn on and nothing happens. When I put the AC adapter on charge the batter LED flashes on and then off. Please may you help...
Hi there its sound like SMPS ( power supply Unit ) problem. Some how he not able to accept the power or hold the power and then forward it. It Is complete hardware problem.
Jan 17, 2011 | Dell Vostro 1000 Laptop
My vostro cannot identify the battery therefore battery cannot be charge
http://support.dell.com/support/edocs/systems/sxl16/en/sm/optical.htm#wp1038494
Most likely unless you have purchased a new battery, the most likely Scenario is that the battery has failed and needs to be replaced
Dec 25, 2010 | Dell Vostro 1000 Notebook
My Dell Vostro 1000 could not start from battery. The seems to be OK, but once its in the pc, it wont start. But if I press the switch and hold it before putting in the battery it will start. Mikel from...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 24, 2010 | Computers & Internet
Dell vostro 1000 Battery is not charging
My battery died within 4 months of getting the machine brand new out of the box.
Crappy batteries I guess?
Aug 12, 2010 | Dell Vostro 1000 Notebook
What about this Dell Vostro 1000 battery
the seller looks ok ...the things to look for is first to be new..no refurbished ,,second try to buy it not formated and do it yourself by charging it for about 12 hours ..and completely empty it for a few times...than see that for the same model of laptop can be more than one model of battery ..different on tha size and so with charge life time bigger or smaller....I will go for a midle size if available ...and use two of them ...to increse independence from the sourse..a much to big one might be inconvenient ...and of course one original is to be prefered on a copy or one that just fits...
the UK site is an excelent choice ...stay away from chinese stuff and cheap deals..
Nov 08, 2009 | Dell Vostro 1000
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
The battery is not identified the system will not charge battery
I had the same problem with my 2 years old vostro 1000. I updated the bios and problem solved.
Sep 03, 2009 | Dell Vostro 1000 Notebook
Batt light flashes 4 red and 1 green over and over vostros laptop
Hi there. If your battery light is flashing 4 red and one green on the battery light indicator (as in the one next to the power and hdd led), then this is an indication that your battery is nearing the end of it's life, and it's time to get a new one. It will last a bit longer, depending on how much you use your laptop, but there will come a time when it won't work at all.
Tim
Apr 20, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dell vostro 1000 laptop
Replace the battery. Their batteries only last 2-3 years max.
Cheers,
gurutim
Mar 20, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1000 Notebook Logo
222 people viewed this question
Alun Cox
