Question about OEM Systems Motorola Bluetooth Headset H500 [OEM] , Baby Pink Headset
Bluetooth snyc problem
I haven't used my bluetooth in a while (close to a year). I charged it & tried to sync it using the directions on the package but get a message 'unable to connect'.
  • Anonymous Jun 13, 2008
    i haven't use my blue tooth headset because it wouldn't work and now i don't know how to turn it on or use it.
I'm going to find my solution somewhere else (probably the manufacturer) b/c they won't charge me $10 to get useless advice from a bunch of amateurs.
Posted on May 27, 2008
Asus laptop how do you get no wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
When you turn on an Asus laptop's Bluetooth function, you allow cell phones, headsets and any other Bluetooth device to be synced with or found on the laptop.
You can use Bluetooth on a laptop to listen to music on a headset or to sync and transfer files from the computer to the device.
If the Asus laptop has Bluetooth wireless technology preinstalled, you can enable Bluetooth access by changing the settings in the control panel.
Click the "Start" menu and open "Control Panel."
Select "Hardware and Sound" and "Bluetooth Devices."
If the "Bluetooth Devices" option doesn't appear, your laptop does not have Bluetooth capability.
Open "Bluetooth Settings."
Click the "Allow Bluetooth devices to find this computer" checkbox in the "Options" tab.
Click "Apply" to save your settings. Click "OK" to close the window.
Change settings for a Bluetooth enabled device
http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device
Jun 10, 2013 | Acer Computers & Internet
Bluetooth connected to x5 but can't play music
You'll have to confirm this with BMW as we have a 650, 135, and X3 not an X5, but your car won't play iphone based music via bluetooth. It will sync contacts, make calls and some other things (particularly with the newer apps) but it won't play your music.
To play your music you have to have the package that allows you to connect your iphone via an iphone cable (usb at one end, iphone connector at the other - what you use to charge it). With this connected you can then see all your music and control your iphone through the screen on the dashoard.
Feb 07, 2013 | 2005 BMW X5
How do you turn the samsung hm3700 bluetooth on? How do you snyc it to your phone?
To turn on the Samsung HM3700 headset, slide the power switch up. (You can see it's location on the image below). The indicator light below the power switch will blink blue 4 times (purple or red means your battery is low). If it stays blue it is ready to sync with your phone.2_29_2012_5_42_10_pm.jpgThere are 3 ways to sync this device to your phone:
  1. Once the headset is on, hold down the talk button for 3 seconds. (the blue light will stay lit for 3 minutes once you enter pairing/syncing mode).
  • Activate Bluetooth on your phone and search for the hm3700 (keep them close to each other).
  • Select the headset and enter a PIN number if asked.
2.) Active Pairing: Once you have held down the talk button for 3 seconds and the blue light is on, press and hold the talk button again to make the blue light purple.
  • The device will try to automatically connect to your phone for 20 seconds. Your phone should not be connected to other Bluetooth devices during this process.
3.) FreeSync is an application you can download if you have an Android (from the Android Marketplace). It allows you to access your headset settings and I believe it can read your text messages for you (text to speech).
For more information the user manual for your Samsung HM3700 Bluetooth headset can be found here: http://downloadcenter.samsung.com/content/UM/201111/20111116163119314/HM3700_UM_America_B_Rev.1.0_110923_screen.pdf
Feb 29, 2012 | Samsung Cell Phones
Ear peice wont charge from the charging dock
If it is under warranty (1 year) Plantronics will replace the headset and charging base case for you. Package up both the headset and the charging case and include your return address, phone number and a copy of your receipt and send to:
Plantronics ATTN: Service Center 345 Encinal Street Santa Cruz, CA 95060
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Discovery 975 (8164001 P)...
How to use bluetoothin aspire 1640z
If there's switch for turning our bluetooth on\off then switch it on, then follow the directions of your bluetooth device manual for syncing it up to your computer. Every device is alittle different, so I'm unable to give you a step by step walk-thru on it. Some bluetooth devices won't "sync" up to your computer. It should say what you can use it with on the box of the device.
Jun 05, 2010 | Acer Aspire 1640Z Notebook
I cant figure out how to talk
The instructional booklet that came with your MadCatz item usually explains what you need to do. If it didn't come with a booklet, try charging it, then syncing it with your PS3 using the PS3's bluetooth sync capability.
Dec 28, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Im trying to sync my H700 bluetooth to my Sprint Palm phone.I have used code 0000 and 1111 and neither is working?
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on the headset is charged before doing this.
If this doesnt work: Start the search on the phone, Keep the boom of the mic closed when you press and hold the button on the h700. the light should turn purple. After this, open the boom
If it asks for a passkey, it will be 0000, four zeros. This is the default passkey for the Moto H700.
Jul 25, 2009 | Motorola Mobility H700 Wireless Headset
Lost manual h700c...how can i get a password to sync?
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Jun 10, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth
I have a LG rumor phone from sprint and I am trying to program my bluetooth samsung WEP 200 and it is saying no bluetooth device found how do I set up the bluetooth I lost my instruction. The bluetooth was previously hooked up to the Razor phone
Sep 11, 2008 | Samsung WEP200 Headset
Sync BlueTooth to TomTom
Tomtom one xl's do not have bluetooth connections for audio. The bluetooth on a TT oneXL is for data transfer only (to update etc).
Unless it has changed in the last 2 months....
Mar 05, 2008 | GPS
OEM Systems Motorola Bluetooth Headset H500 [OEM] , Baby Pink Headset Logo
209 people viewed this question
Top OEM Systems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an OEM Systems Radio Communication Expert? Answer questions, earn points and help others
