GPS Logo
Posted on Oct 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Garmin Nuvi GPS touchscreen stopped working. What can I do to fix it?
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Oct 02, 2010
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
684329
Points
8555
The touchscreens are attached with either a ribbon connector, or a heat-pressed connection, depending on the manufacturer. You would have to take the unit apart to see what's going on. If it's a ribbon connector, you can redo it's connection to the main board. If it's a heat connection, the unit will have to be serviced.
I saw a video on YouTube where someone took their ipod apart and reheated the connection with an iron, but it was quite a process.
I couldn't find a touch GPS screen video, but here is an ipod video:
http://www.youtube.com/watch?v=u4WCOANs4tU&p=8434115697009241&playnext=1&index=11
Good luck, and hope this helps.
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 • GPS
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
2answers
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
The screen in my garmin nuvi 680 is no work
You will need to recalibrate your screen. If the screen is not working at all, you can go search for the support article at Garmin. Use the keywords touchscreen and 600. This may temporarily fix the problem, but if you have a lemon, the touchscreen may need to be replaced. (The solution is also posted at this site from other users.)
4helpful
Touchscreen doesn't work. It happened suddenly. Garmin nuvi 255
try recalibrating the sceen. to access, turn unit on but hold power switch to the left until touchscreen config shows (35-60 seconds) follow prompts onscreen
1helpful
1helpful
Touchscreen on garmin nuvi 680 GPS stopped working
Try reseting the nuvi, there is a reset button on the bottom or on the back, some models have it on the front under the display cover.
if that doesn't help the digitizer which is the part on top of the lcd display that registers the touch could have failed and may need to be replaced.
I haven't seen many garmin repairers, you might have to get in touch with garmin about it, check ebay for replacement parts but if I remember correctly garmin takes care of it and don't distripute much parts.
Sep 10, 2009 • Garmin GPS
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
