Question about Miller Electric Manufacturing Electric Syncrowave 250 DX TIG 907194032 Welder
I have a syncrowave 250, it is about 12 years old. I bought it new and use it rarely. Recently I went to weld some light aluminum and when I tried to start an arc,it acted as though I had no ground connection. I checked everything and it was O.K. I tried again and got a little better arc but not normal. I kept the unit on and rolled up to 225 amps and back down several times. The arc got better the longer I stayed on it, until it seemed normal and I finished my job. I went to use it again about 2 weeks later and got the same issue. I have tried one time since and the same. I've checked the obvious ie; connections,gas,tungsten etc. Any suggestions??? Thanks, Jon.
    New Friend:
  • 15 Answers
Jon,
I would like to suggest to you that you post this question on the millerwelds forum. There are some very experienced tech guys there that can help you much better. Go to millerwelds.com and select the forums under the resources tab. You will be surprised. Hope you can get it running again.
Ryan
Posted on Apr 21, 2017
  • 10 Answers
SOURCE: how to prepare tungsten for aluminum
To make successful aluminum welds you must set your TIG machine to A/C, so make sure you get a tungsten rod meant for running alternating current. If it is pure tungsten (green band on the end), you're good. For the tip, just grind a tip like you normally would. When you start welding a bit of aluminum will collect on your electrode. After that you may need to break off the tip every now and then if you get a lot of junk in the ball. Make sure you practice on some scrap first, aluminum is very different to run than other metals. Getting the right operating temperature down is a bit trickier too.
Just in case you're working on something serious like a motorcycle frame, make sure the aluminum you're using is a grade that's able to be welded. I've heard about a guy that built costom bikes and used the wrong grade, when the customer took the bike down the highway it fell apart on him.
Posted on Aug 08, 2009
Richie_asg1
  • 1036 Answers
SOURCE: my tungsten appers to be melting when i am welding
What gas are you running ?
Aluminium needs Argon mix - try increasing gas rate to provide sufficient shielding - and work indoors.
If this doesn't solve it -
Try using a lower amperage as I think you may be overheating. Alternatively - use a different make of tungsten.
Don't dip electrode, as this will eat it up.
Posted on Aug 28, 2009
  • 24 Answers
SOURCE: cannot get syncrowave to weld aluminum
must use remote output for tig
Posted on Sep 18, 2009
co7196
  • 3433 Answers
SOURCE: Miller Syncrowave 200 wont strike arc for TIG
proper polarity?
Posted on Nov 12, 2009
mxtras
  • 194 Answers
SOURCE: I have a miller microwave 200. what settings
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Posted on Jan 12, 2010
Can't get Syncrowave 250 to stick weld
Here's a discussion on the subject:
http://www.millerwelds.com/resources/communities/mboard/forum/welding-discussions/25062-stick-welding-with-250-dx-syncrowave
Feb 21, 2018 | Welding Tools
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
    Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
    Oct 08, 2011 | Miller Electric Manufacturing Electric...
    Syncrowave 250 dx aluminum set up
    You can go to millerwelds.com and download the manual for this machine..it should help you
    Dec 13, 2009 | Miller Electric Manufacturing Electric...
    My tungsten appers to be melting when i am welding aluminum also leaves black residue when welding
    TIG TORCH MAY NOT BE RATED AT THAT AMPERAGE .MIGHT BE BETTER TO USE 1/8 PURE TUNGSTEN. BLACK RESIDUE MAY BE CAUSED THE CORROSION OF COPPER GUTZ DURING WELING ,DO TO INTENSE HEAT. OR MAYBE CAUSED BY FAILURE TO CLEAN METAL AND/OR DIPPING THE TUNGSTEN.
    Jul 02, 2009 | Miller Syncrowave 200 Tig Welder Cover...
    Dirty weld
    clean your metal with a good peace of the green scotch guard scrub pad prior to the weld.Also try turning up your gas and move a little faster when using filler wire,rember to much heat causes a darker dirter weld.hope this helps
    Dec 28, 2008 | Welding Tools
    Welding aluminum
    TIG weding is next to brain surgery as far as CLEAN goes.
    You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
    Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
    Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
    In short you must get everything perfect to get quality Heliarc Al welds.
    Good luck, HowardRoark
    Dec 22, 2008 | Miller Electric Manufacturing Electric...
    TIG welder help
    Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
    Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    Miller Electric Manufacturing  Electric Syncrowave  250 DX TIG 907194032 Welder Logo
    1,067 people viewed this question
    Top Miller Welding Tools Experts
    Robert Lee
    Level 1 Expert
    Kory Ronning
    Robert Monigold
    Robert Monigold
    Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
