Question about Bally Total Fitness Exercise Ball
I have a Bally mini stair stepper, and the pulley broke. How would I order another part?
Wider mini stair stepper
Hi
The tension knob should have a plus and a minus on it if you turn it towards plus it should make the stepping harder and obviously the minus makes it easier
Hope this helps Nick
Aug 20, 2017 | Sewing Machines
Belt slipping off pulley of stairmaster
It may be time to replace your belt, but here is something to try before doing so. There should be a set screw on the pulley. You can loosen the set screw and slide the pulley to allow it to better align with the alternator pulley. Give this a try.
Alternator Drive Belt Timing Type SPORTSMITH net
Poly Alternator Belt for Stairmaster Steppers SM20202 SPORTSMITH net
Sep 30, 2013 | Stairmaster Stepmill 7000 Pt
Cybex 500 stair climbers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am not 100% sure of your question, but the following link will take you to our page for the Cybex 500 machines.
Cybex Tectrix Stepper Parts for 500S 1000 Climbers Belts Pulley Cable...
Jul 28, 2013 | Exercise & Fitness
Parts
This cable can be ordered from our Website. Please have your exact model and serial number ready. The following link will take you to our Tectrix stepper page.
Tectrix Cybex Stepper Parts Climbmax Personal Climber 2000 3000 Model 150...
May 07, 2013 | RTO Tectrix Personal Stair Climber
Stair master 4400cl Stepper making clunking sound user pedals when stepping
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Apr 03, 2012 | Stairmaster 4400CL Stepper
Bally Mini Stepper Broken Pulley
Hi mine is not even a yr old and the pully broke, where can i find a pully.
Feb 12, 2012 | Exercise & Fitness
Stair stepper won't start
Wide Ride Pedal CTGID0 Stair stepper won't start
Dec 01, 2008 | Schwinn Wide Ride Pedal
Bally Total Fitness Exercise Ball Logo
170 people viewed this question
Top Bally Sport & Outdoor - Others Experts
Bill Eager
Are you a Bally Sport and Outdoor - Other Expert? Answer questions, earn points and help others
